Question about D-Link DIR655 Router
Hello, I'm having a problem with my D-Link DIR-655 Extreme N Gigabit Wireless Router. After using the installation disc, I tried testing the internet speed using one of the gigabit ports and it was only getting less than 2mbps for download speed and 1.80mbps (upload speed was unaffected), my ISP (Road Runner) provides me with 15mbps download speed and 1.80mbps upload speed plus turbo boost. I tried disabling a number of features but nothing worked, I really need help with this, thank you.
5 Suggested Answers
peping
  • 99 Answers
SOURCE: d-link 2640
i think your problem is the configuration,in the security of your wap.try to configure it again.
Posted on Mar 13, 2008
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
SOURCE: How to connect USB NAS to D-Link DIR 655
when you run the start up disk that came with the router there is an option to install "SharePort" after installing this program my 655 found the hdd no problem
Posted on Feb 15, 2010
devverma143
  • 163 Answers
SOURCE: D-Link Wireless-N GigaBit Router(DIR-655) using SmartBro Broadbnd
first of check for the ip address of D-Link wireless. Then try to open it in the internet explorer. give the username and password. then go to wireless option and select the security protocol wap or wep. Provide a network password. Set the DHCP range and save & exit and restart the wireless. Then try to ping from ur pc
Posted on Apr 20, 2010
How do I make my D-link extreme N dir-655 stop losing connection throughout the day. Is there a power setting that I can adjust.
There could be any number of things causing a wireless router/computer to lose connection. Please click on this link and follow my instructions to find a possible solution to your problem :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
May 22, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I want to reset my router password to be able to get the network key. I'm in the D-Link wireless router's administration interface but I don't know the default password. I'm trying to...
You can go to this website for reference. The default user name is Admin and the password is blank.
http://www.speedguide.net/routers/d-link-dir-655-draft-n-gigabit-router-177
Regards,
May 15, 2011 | D-Link Xtreme N DIR-655 Wireless Router
D-Link 655: Need To Secure (lock) Router.It's Unsecured right now?
go to this link
http://www.dlink.com/support/faqDetail/?prod_id=2484&print=1
to secure your wireless network using WPA.
Mar 19, 2011 | D-Link - Xtreme N DIR-655 Gigabit Router -...
Apr 19, 2010 | Computers & Internet
I have a DIR 655 D Link router and I can't save changes.
Lots of possibilities, especially if the wireless device and your PC are older - the DIR 655 doesn't support wireless protocols 802.11 a and b, for example, only the newer g and n.
Start with getting the router software up to date (see http://us.dlink.com/products/connect/wireless-n-gigabit-router/ )
using an Ethernet link to a PC, and then debug the wireless access. The DNS message could be caused by the Windows wireless adapter config having a manual IP address vs the router being set for DHCP (dynamic) or vice versa.
Sep 10, 2017 | D-Link DIR-655 Wireless Router
DIR-655 does not allow Avaya VOIP phone to work
You need to check the DHCP configuration on your router. Also try setting up a static IP on your VOIP phone & try.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
DIR-655 Connection Support
Don't worry about it, The router is backward compatible to B,G and N only. the Router that your is wireless extreme N. Some of the A, D is not been supported by the router that means that we are on a new generation, there some older router can support the A,D.
Jun 27, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DIR655 Router Logo
95 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
