Question about Timex Watches
Can't get to Eastern Time (TO65-A-A)? - Timex Watches
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
How do i adjust my ipad to Vancouver time?
Just perform either an update or plug it into your computer
Nov 06, 2014 | Watches
Set time zone on centrios atomic clock
1. In the normal time mode, Press MODE key to enter the alarm time mode .
2 Press SET key to change the time zone, P is pacific, m is mountain c is central and e is eastern.
Nov 26, 2010 | Watches
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
Aug 10, 2010 | Timex Automatic Watch
My husband's watch keeps resetting to 1/1/05 Eastern time. I've reset it a few times and its good for a few days then back to 1/1/05 Eastern. We live in the West and it's 2010 (so he can look at his watch...
Hi,the problem is either from a weak battery or a mechanical fault in the engine of the watch,
i think you should replace the battery,if the problem persists afterwards,then it's time to give him a wrist watch as a birthday gift.
Be cool.
Jun 13, 2010 | Casio Waveceptor WVA104HA-1AV Wrist Watch
I live in Eastern Time Zone. My atomic clock shows map of USA in top right hand corner and it is set in Western Time Zone. How do I reset to Eastern Time Zone? I have had atomic clock for several years. I...
The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
Feb 25, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
Cannot delete
My watch has a tiny letter just to the right of the signal strength indicator. In my case it is a C because I live in the central time zone. Perhaps you live in the eastern time zone? The E may not be short for ERROR but instead stands for EASTERN. Its called the E/C/M/P indicator.
I don't know if you have had a chance yet, but the manual that I talked about previously does show this feature on the first page. Its called "Operation Guide 2608 2638 2688". Your watch almost certainly has a 2688 module.
I hope that was the E that you were talking about.
As for the signal sign, you want it to be there. You need to worry when its absent. :-) I think all waveceptors are like that.
I hope that helps.
Dec 27, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Silicon radio control watch, what # is the eastern zone
It depends which way you are looking at- West or East.
5th time zone on West is for: Greenland, Canada, USA, Bahamas, Jamaica, Columbia, Peru.
On East: Russia, Kazakstan, Uzbekistan, Afghanistan, Pakistan, India, Maldives.
I just do not understand why you do need this. All radio controlled watches are receiving the signal from the place in country where watch is worn- in my case its Rugby in England.
Use your user manual to sort this out.
Dec 11, 2008 | Bulova Watch
Watches Logo
67 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
