Switch TV on then 5 seconds later switches itself off
  • 2 more comments
  • Kevan197171 Aug 03, 2008
    I switch it on, the green light comes on for about 5 seconds, then that goes off then the red standby light comes on but their is no noise.
    The TV is Matsui LM20N2
    the standby light doesn't blink, just how it should be
    Thanks
  • 10,594 Answers
I think, your TV gives High Bright Green Light on screen and then goes to standby. Its indication of defective Green CRT (Picture Tube). Rear projection TV has 3 CRTs i.e Red-Green-Blue. In your case, Green CRT seems defective and need to be replaced.
Posted on Aug 03, 2008
    Guru:
  • 1,894 Answers
This is a problem due to heating of some component in the power board or main board
this is the reason for the unit to turn off with out any reason.
this can be due to a bad component or a bad connection.
you will have to manually inspect the board for the problem.
  • 19,396 Answers
The safety switch is turning off TV by itself. It menas there is a problem inside tv, a short, a blown capacitor od a faulty IC. Pcbs must be tested with a multimeter. Unless you are an expert electronic DIYer you will need a technician to fix this.
    Brigadier General:
  • 6,966 Answers
this often indicates that the built-in protection system has kicked in to prevent any (further) damaged to the TV unit. Depending on the brand and model, the lights would be blinking signifying a code that could lead to the probable area of fault.
Initially, you could try to reset (unplug from the mains for a few hours), hoping that it is just a glitch and with the reset, system would revert back to factory defaults.
Hope this be of initial help/idea. Pls post back on the make and model, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 120 Answers
Do you hear any ticking sound while it turns off?
and are you able to see any blinks of the red light in a particular pattern?
that will help to decode the problem easily
  • Aiswaria Sekar
    Aiswaria Sekar Aug 03, 2008
    and the red stand by light is still or blinks?
    if blinks.. how many times?
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
We have a Hitachi C28W1TN, which is just under 10 years old that has recently started switching itself off. It goes onto standby by itself and when we switch it back on, it instantly does it again. At...
It's been a while since this post, but I may have had a similar problem with my Hitachi. With no reason it would switching on and off randomly. The problem was with a solder joint on main relay - it was cracked and would not keep the coil powered so i kept flickering on/off. This relay is located on the front of pcb, between high voltage area and the switch and on my tv it is blue. Check all four joints and apply some new solder onto them. Make sure the tv is not connected to mains ;-) Hope this helps
Oct 26, 2008 | Televison & Video
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
May 27, 2008 | RCA 32F531T 32" TV
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
Loewe Aconda 9381 HD/DR+ Will not switch
Could be loss of voltage on secondary or problem on Power supply. Check 4/5 (depnding on chassis) wickman fuses on secondary if none are o/c then replace power supply components with Kit from Loewe. Part number 90415.900.
Should take tv engineer about 1 hour (max) to replace parts form kit.
Aug 08, 2007 | Loewe ARC332 32" TV
TV Akai CT29X4AV
Have tried checking if the Power Plug is fitting tightly in the Power socket? Could be that it is loose?
May 27, 2007 | Akai CTS2550 25" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
