Question about Garden
The drive gear has shredded and I need a new one. It is a 1991 Chamberlain 1/2 HP Heavy Duty Model 5000. I cannot find the manual to explain what the part is to replace it.
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
The manual can be found here:
http://homeappliance.manualsonline.com/manuals/mfg/chamberlain/5000.html
This is usually the parts that fail:
http://www.wholesalegaragedoorparts.com/Gear_Kits.htm
PN: 41A2817 For the worm gear drive parts
PN: 41A2827 For the Sprocket and Gear Drive assembly that includes the worm drive.
Chamberlan customer support phone: (800) 528-5880
Thanks for choosing FixYa,
Kelly
Posted on Mar 23, 2011
Our garage door won't open all the way. It stops just short of being open all the way but not enough to get the car out. What is the problem? Can we fix it ourself?
Hello Pat Remus,
Chamberlain... Has been around for a very long time
... type of door... presumed to be OVER-HEAD...
Operation issues .... (were okay (?) sudden fialure
is likely a BROKEN BALANCE SPRING
EASY to check...
CAUTION: doors can be EXTREMELY heavy.
FROM the closed position... (to avoid a door crash)...
You should be able to disconnect your GARAGE
opener... and feel the well balanced motion rom the
full open to FULL closed.
If you hear any chatter of springs.
THEY need to be lubed (often)...
ELSE
That "chatter"
will turn into "SHATTER"...
Those springs will break... and need to be replaced
( pretty RISKY job best done by a SERVICE company )...
If the door is quiet & well balanced...
Then it is time to check the "travel" contacts...
and adjust them the the proper HEIGHT is achieved.
>> READ THE MANUAL... OWNERS (model??)
No exact matches found Try these results
Hope this helps...
Carnac the Magnificent
Dec 07, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
When i change my drive belt it gets shreded on start up
Sounds like either the belt is not tight or more likely your door balance is heavy ie fatigued/broken springs or its hung up somewhere.
Apr 16, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
Chain on garage door not moving but motor is running. Model 1255SCR 1/2 HP.
This means that the nylon drive gear in your unit has been stripped. This can be replaced and is common in openers. You can get a replacement at chamberlain.com. It does take moderate skill to do and should take about an hour to complete. You can order the gear by itself or the whole drive shaft. Make sure and set the limits per the manual and do a 2x4 safety reversal test afterward. Thanks BB
Sep 11, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Have broken the drive gear twice Chamberlain garage door opener
There are two main reasons for the drive gear to strip the teeth. The first and most often cause is a heavy door. With a door opener we never lift the door manually so we don't know how heavy it is getting when it needs maintenance. The second cause is what may be your problem and that is lack of lubricant. In the gear kit there is a tube of grease that should be used on the gear. You just can't use too much. You may need new door springs.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2 hp heavy duty garage door opener stops working until you tap hard on the back of the box to get it going again. Not even the tapping will get it started now.
I have three of these openers and all have failed after several years use from the plastic drive gear wearing out, so without seeing your unit, that's what I would guess. The gear is relatively easy to replace and I bought parts from a company called "gatehouse" (www.gatehousesupplies.com). I've only used them once, but I am pleased with the service. Good luck.
Jun 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Can I get the specs for belt 727 A? I need to replace this weekend and ARDISAM won't give me a size. Can't afford to overnight. Earthquake Gear Drive 5 HP rototiller. would appreciate help=
DID THE BELT SHRED OR what happened if it is still decent mesure width on top is it a v-shape belt or flat & last thing is cut it & measure it if its still decent that will give you the specs or if theres other # on belt & who its made by
Jun 05, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Liftmaster 1/2hp problem with shredding gear shift really fast
DOES THE DOOR WORK SMOOTHLY AND EASILY MANUALLY??
IF NOT THAT WILL CHEW UP YOUR GEARS.
IF THE DOOR WORKS WELL MANUALLY I AM GUESSING YOU ONLY REPLACED THE EASY GEAR.
YOU NEED TO REPLACE *BOTH* GEARS - FOLLOW THE INSTUCTIONS COMPLETELY. THE SECOND ONE IS HARD TO CHANGE BUT IF YOU DON'T THE ROUGH SURFACE OF THE HARDER WORN GEAR WILL CHEW AT THE NEW GEAR AND ..... WELL YOU HAVE SEEN THE RESULTS.
HOPE THIS HELPS
Mar 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
