Question about Panasonic SCPT480 Theater System
I have a lg plasma tv tryin to get the panasonic scpt480 connected i have sound threw dvd player but not tv wat cables should i use
  • 961 Answers
There are a couple of different ways you could go with this. Your Panasonic SCP-T480 has an HDMI and a digital optical port HDMI carries audio and video signal so, it would be your easiest/best bet. Digital Optical provdes sound only but, provides as good sound quality as HDMI but, no video To use the digital optical for sound you would also have a composite(RCA) cable to gain your video.
Posted on Mar 23, 2011
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
Im tryna hook up my pansonic sa-pt 480 surround sound to my 42 inch plasma panasonic flatscreen and the cable but the sound not coming out the speakers
I couldn't find any info on sa-pt480 only scpt480. However, setup should be straighforwardly the same.
Generally you have to direct the sound in setup. The manual is here http://www.mito-oem.com/media/pdf/SCPT480.pdf Follow the instructions for setup
Mar 13, 2011 | Audio Players & Recorders
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Mar 07, 2011 | Panasonic SCPT480 Theater System
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
Dec 18, 2009 | Panasonic Televison & Video
How to connect a humax foxsat-hd to a panasonic dmr 75eb recorder,to a panasonic th42px60b plasma tv,also will i get better result using component cable instead of scart lead. please can you...
You plug the humax into the panasonic dvd recorder and then from the outputs of the dvd recorder plug it into the panasonic plasma inputs
Is component video better than RGB? Well, yes and no, RGB provides the widest bandwidth and is the best choice for connecting audio visual devices like a Freeview box, digibox or Sky+ box to your TV, home cinema or home theatre system. DVD is however different, to reduce the amount of storage required DVDs are recorded using component video, it is therefore better to connect a DVD player via a component video cable to your TV, plasma or LCD TV etc.
Thanks if you have any questions please do not hesitate to ask
Dec 02, 2008 | Televison & Video
Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Jun 01, 2008 | Denon AVR-4308CI Receiver
Panasonic Viera 37 inch Plasma won't read DVD player
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
Mar 16, 2008 | Televison & Video
Trying to connect dvd player
You will have to connect your DVD player to the plasma TV, not the cable box. The cable box (or most cable boxes) have video outputs only. The same is true for the DVD player: it outputs the video to the tv.
Look in your DVD manual for scenarios for connecting your player to the tv.
Mike
Dec 06, 2007 | Panasonic DVD-S27 DVD Player
Panasonic SCPT480 Theater System Logo
154 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
