Question about Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME
I just installed a Tuscany Asti shower body. The hot and cold are reversed...the instruction booklet says, "the water supply can be modified to correct the orientation without changing the pipe locations". The cartridge and entire housing only SEEMS to go one way. I don't see how the cartridge can be turned 180 degrees...??????? Everything in this unit seems only to fit one way....? Is the booklet for another unit?
    Scholar:
  • 82 Answers
My booklet says "remove the cap by hand, remove the eclip from the cartridge body with pliers, remove the stem ring from the cartridge body with pliers, reverse teh cartridge stem by turning 180deg. It is not necessary to remove the cartridge from the body. Make sure the flat side of the stem ring is on top and re-assemble in reverse order." or something to that effect.
Posted on Oct 08, 2013
2 Suggested Answers
  • 15 Answers
SOURCE: jsut installed a tuscany Asti
Water backs up to the shower when the internal dimension (ID) of the pipe between the valve and the spout is not large enough to handle the volume of water that is running through the valve. My guess is you used pex. You should have used galvanized or copper pipe. The ID of galvanized pipe is 5/8"; copper pipe is just over a 1/2" ID. This will fix the problem. If this pipe is no longer accessible, you may be able to fix this one other way, by limiting the volume of water that is supplied to the valve. Remove the handle and the escutcheon plate. Turn screw on each side of the valve clockwise until fully closed; this will shut the water off to the valve. Now, put the handle back on and turn the faucet on full mix; water should not be running. Now turn each screw 90 degrees; water will begin to flow. Wait 20 seconds to see if water backs up to the shower. If not, turn both screws another 90 degrees and wait 20 seconds again to see if it backs up to shower. Continue this until it backs up to the shower. When it backs up, close each screw equally until it stops backing up.
Posted on Feb 24, 2011
I installed a Tuscany shower valve and the hot and cold are reversed. I didn;t change any of the piping and hope there is a way to adjust with the cartridge. Help!
I am not familiar with that valve, but I hope I can offer some help. It may be that you installed the valve upside down. Every shower valve I have ever installed has writing on the back that says; UP. If you still have access to the rough-in valve, you may want to check that. Also, if it is installed upside down, you can try to pull the cartridge, flip it and reinstall it. That does not work with all cartridges, but it is worth trying if the rough-in is installed upside down.
Oct 17, 2014 | Home
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape.
First and foremost, read the install instructions that come with the new shower head...
After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water.
Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube.
Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench.
You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall.
To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head.
Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently.
Here's a nice short video on the subject, illustrating my instructions: http://youtu.be/fiv4Zq9v4co
Jul 27, 2014 | Delta Faucet Home
We have a tuscany/Asti tub and shower faucet and we just installed it and when we turn it on the water starts coming out of the shower, without pulling the knob for the shower to turn on. Any ideas?
The knob is most likely binding or just stuck a little try putting a drop or two or oil, WD-40, or even cooking oil on the knob shaft, work the shaft up and down to spread the oil and see how it goes. Worse case you have a cracked knob shaft and then you will have to take it back where you bought it or see if they can give you a knob shaft and replace it, as I said worse case scenario. Good Luck...
Jun 04, 2011 | Home
Jsut installed a tuscany Asti Tub and Shower Faucet, when the mixer handle is centered and you are running thru tub spout, water still comes out of shower pipe. it does not do this if solely set to hot or...
Check the valve body to make sure it is right side up. there will be a marking on the valve that tells witch is to go to the tub spout and witch to the shower head. If you have it right then you will need to disassemble the valve body and look for debris in the cartridge.
Feb 11, 2011 | Ldr Industries Home
No hot water comes out of shower just cold comes out even when turned to hot, sink 2 feet away has hot water
The problem more tha likely lies within the shower valve body. Possibly the shower head has an accumulation of deposits clogging up the holes but that would not affect the hot water supply only. You might try removing the shower head and turning on the hot water. If you get hot, immerse the head in Limeaway for a hour or two and replace it, or install a new head. If you still do not get hot water, the shower valve needs attention. The cartridge inside the valve body will likely need replacing or at the least cleaning (Limeaway), replacing rubber seals and use plenty of silicone grease before re-assembly.
Oct 26, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Hot side is cold cold side is hot
hello, this can happen if the shower body unit was installed incorrectly, the installer connected the hot to the cold side and cold to the hot side, what you can do might be a bit difficult but the water supply lines are reversed you need to open up the wall and attach the cold and hot lines to the right sides.. hope this helps
Jun 04, 2010 | Moen Monticello Collection 1 handle Shower...
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Mar 18, 2010 | Delta & Single Handle Shower Faucet
Kohler shower valve (hot/cold switched)
Just had this same thing, on this exact faucet. If you still have the manual, it has instructions on how to rotate the valve for back to back installations where one shower has the hot/cold reversed. Our contractor got ours in backwards the first time and I had to call and have them come out and rotate the valve this morning.
Dec 19, 2009 | Kohler Forte entertainment remote valve...
Sterling shower faucet
The problem is that the supply lines feeding that faucet are reversed. That is the cold supply line is feeding the hot side of the faucet and the hot supply line is feeding the cold side.
The fix is to reverse the supply lines where ever they can be most easliy accessed.
Apr 14, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME Logo
268 people viewed this question
Top Ldr Industries Home Experts
john h
Tom Chichester
Are you a Ldr Industries Home Expert? Answer questions, earn points and help others
