Radiant heater, natural gas. Piezoelectric starter seems to work perfectly, nice healthy spark, right where it should be. Gas flows like it should but it doesn't light with the piezoe. It lights right away with a lighter. I cleaned the nozzle; it was not dirty. It used to work on the first push of the piezoe, then it took a few times now you could bang on it 50 times before it lights. I tried adjusting the position of the electrode but it looks perfect. Whats up??
    Brigadier General:
  • 4,736 Answers
Disconnect (pull off) the wire from the piezo pin on the bottom of the piezo, then slide it back on. If it had lost it's ground,which I think it did, that should solve the problem.
Posted on Mar 23, 2011
Pro Com 30,000 natural gas radiant (not blue flame) wall heater gets so hot I cant touch cabinet . what is the most likely cause?
If not blue is it yellow ? Could be too much gas to heater check reg , might need cleaning burner , thermostat if fitted not working ..
Oct 31, 2016 | Heating & Cooling
No spark. My HSU75NG MR. Heater (Big Maxx) will not start on its own. It purges fine ,calls for heat fine, gas flows fine; BUT there is no spark from the Electrode Igniter. Which I have replaced. The
The capacitor in that unit is for starting the motor that drives the blower fan. It has no impact on the ignition of the gas burner. On the control board, there is a light that should be flashing, can you tell us how many times it is flashing?
Feb 18, 2014 | Mr. Heater Natural Gas Garage Heater -...
My brand new 38 gallon GE water heater does not ignite. I follow the instructions, hold down button in pilot position, heater dial in pilot mode and push the piezoelectric button several times. I look...
Check that gas is turned ON. Gas handle is parallel same direction as gas line.
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
Make sure that type of gas matches water heater. Natural gas and propane gas are two different types of gas. check label on side of tank for type of gas NG or LP.
Call GE 1-800-432-2737
Copy following links:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene
h
Aug 11, 2013 | General Electric Water Heaters
Kenmore Elite He3 gas dryer (110-92832100) not heating. Igniter glows red for a min or so, drum spins, hear a loud 'buzzing' noise....
The problem could be flame radiant sensor or in most cases the gas valve solenoid coils sitting on top of the gas valves. The radiant sensor must be aligned perfectly with the igniter. The radiant sensor contacts bypasses one of the gas valve solenoid coils and as the igniter heats up it makes the sensor contact trips unbypassing the coil and allowing the gas to flow and be ignited.
The problem is with the solenoid coils,
one with 2-prongs and the other has 3, if the radiant sensor is aligned with igniter and working perfectly but no gas is ignited. The buzzing sound is coming from the coils trying to operate the valves. Replacing both coils is the simple and only viable solution.
Jul 18, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Empire Corcho radiant nature gas space heater that the middle brick panel flairs when on. When the other two bricks light they burn normal (ie no flair or flames except slight flame as bricks heat...
Problem sounds like the incoming gas pressure is too high or the burner below the middle brick has debris or trash clogging some of the openings. Recommended next step is to remove all power / natural gas to the space heater and check all burners for debris or blockage. If burners are clear have your natural gas provider test the incoming gas pressure to ensure it is correct for that appliance.
Dec 13, 2017 | Heating & Cooling
I have an old cozy natural gas heater that cuts off at night
Remove and clean all electreical connections in the unit.
Dec 26, 2009 | Cozy Heating & Cooling
Bosch 1600H won't work on windy days
The incorporation of an anti-back flow, flue pipe insert may be your solution, also the pilot flame control may need to be adjusted up a little.
Good luck
Aduz
Mar 24, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H NG
I hope this helps!
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/1600HTechSupport/Troubleshoot/tabid/1094/Default.aspx
Copy and paste to google search engine!
Jan 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Turning on a radiant heater
whoo tall order! well, since that unit uses a piezo crystal spark gap that's half the battle. go to the grainger site and find a 24 volt electrically operated solenoid for gas use. anything else won't do. next go to the white rodges web site and find a spark igniter with a flame rod flame detector 24 volt. you'll also need at least a 500va 120/24 volt transformer. a standard honeywell stat will do. I'm thinking the unit uses a millivolt generator to keep the gas valve open. you could substitute a mercury button cell to energize the pilot valve and keep the valve open. give me your email addy and I'll see if I can draw up a diagram for you.
Dec 13, 2007 | Heating & Cooling
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
