Question about GE Spectra JGBP35 Gas Kitchen Range
My lower oven does not work. Broiler and all rest work fine? Any ideas what the problem may be? Igniter? Thanks
  • 403 Answers
You are right on the money, the igniter probably needs to be replaced. remove shelves from oven. remove bottom panel. remove flame shield, Turn the oven on and examine the glow from the igniter, it should be a real bright light, and should go from off to bright in a few seconds. If the glow is slow, or no glow at all, then thats your problem.
Posted on Mar 23, 2011
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
XL44 oven will not work
The fact that the igniter on the broiler actually begins to glow rules out your Electronic Oven Control (EOC) board. Usually when both oven features fail to work the EOC, or wiring, is the culprit. But...in your situation, the broiler igniter glows, but the bake igniter doesn't. You don't see this happen very often, but I believe you may have two bad igniters. The following link explains how to replace an igniter and gives you some theory behind how they operate:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Although an igniter glows, it still may be bad. This is usually dependent upon the age of the stove and the frequency of use. Usually, the bake igniter burns out first, because it is used more often. These igniters also grow weak with age. Which means, if they do not draw the required current necessary to open the gas safety valve, you will not have ignition. This is a designed safety feature that prevents free flowing gas from filling the oven box before ignition. I would recommend replacing both igniters to see if this corrects your problem. If you require additional assistance, or have questions, please let me know before you rate the solution. I hope this helps solve your problem.
Feb 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
Oven issue
Most likely you need to replace the WB2X9154 oven igniter. Remove the floor of the oven (two screws at the back wall) and lift back edge up first, then take out the rest of the way. One nut holds the flame spreader. This gets you to the burner assembly. The igniter is the round thing on the side, near the back. Do an "ask me" if you have more questions. If this helps, a "fix ya" rating would be appreciated. Thanks.
Sep 22, 2008 | Ovens
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
Replacing Oven Igniter
PULL OUT THE DRAWER AND THAT WILL ALLOW YOU ACCESS TO THE 1/4" SCREWS IN THE LOWER REAR THAT HOLDS THE BURNER IN PLACE ALONG WITH THE FRONT SINGLE 1/4" SCREW. NEED A FLASHLIGHT FOR THIS. THIS FREES UP THE BURNER SO YOU CAN ACCESS THE IGNITER MOUNT SCREWS.
Feb 14, 2007 | GE Spectra JGBP35 Gas Kitchen Range
GE Spectra JGBP35 Gas Kitchen Range Logo
71 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
