Question about Hitachi RD4056P 5.6-Cup Rice Cooker
How much water do you add to the rice? - Hitachi RD4056P 5.6-Cup Rice Cooker
    Genius:
  • 1,114 Answers
It is a 1 to 1 ratio.
Posted on Mar 23, 2011
Iv'e purchased a 5 cup homemaker rice cooker but your leaflet dosen't explain how much rice or water ratio
I am sure that there is some official rice water ratio, but my method works for me.
1. Rinse the rice until no more "white" comes off of it and the water runs clear.
2. Let sit for one hour in water.
3. Drain water.
4. Add water to 1" over the top of rice and start in cooker.
5. Add 1 cup of water per day until rice is used up.
Jun 25, 2011 | Microwave Ovens
Lost manual; what is ratio of rice to water? thanks!
All right, this can be a bit confusing. IF you still have the cup that came with your Rice Cooker, use it to measure your rice. Then, inside the cooker there are lines showing how much water to add based on how many of the Zojirushi measuring cups you used of rice. THAT's simple.
IF you DON'T still have your Rice Maker measuring cup you will have to use a 3/4 cup U.S measuring cup. This equals the same amount as the rice cooker cup. For each 3/4 cup of rice you use, add that many cups of water. If you use 3/4 cups of rice twice, then add water to the 2 line.
In other words, a rice cooker measuring cup equals 3/4 cup of regular U.S measuring cups.
Hope I didn't confuse this too much. I hope this helps and if it does, please let Fixya know by rating my solution. Good luck and happy cooking!
Nov 15, 2010 | Zojirushi NRC-18 10-Cup Rice Cooker
Lost direction on how to use my rice cooker and havn't used it in a while
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Please rate this answer. Thank you.
Mar 27, 2010 | West Bend 86712 12-Cup Rice Cooker
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
DO YOU PUT WATER IN THE MAIN COOKER BODY BEFORE PUTTING THE ALUMINIUM BOWL WITH RICE AND WATER INTO.I HAVE SR-928 PANASONIC ELECTRIC RICE COOKER.
I do not think you would add water to the cooker. You simply add water and rice to the bowl.
Mine works great. I put 2 cups water and 1 cup rice.I add a tad of salt and olive oil. I cover the lid. set that into the cookerI press the lever. When the rice is done the lever pops up like a toaster. Note. Unplug the cooker when rice is done. that is how mine works. I would be willing to bet it is how yours works too.
Jul 21, 2009 | Kitchen Appliances - Others
Cooking rice procedure?
Here is the manual it will tell you how to cook the rice.
http://www.blackanddeckerappliances.com/dyn/prod/user-guide/83/HS800.pdf
Good Luck and Please Rate FixYa!
Jan 20, 2009 | Black & Decker HS80 Rice Cooker
Rice cooker
The rice will stick if there's not the right amount of water added.
The rice cooker should have numbers marked on the side of the pot. Those number correspond to the amount of water to be added for a given amount of rice. For instance, if you add 4 cups of rice, add water until it reaches the 4 mark.
Sep 14, 2008 | Toastmaster Kitchen Appliances - Others
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Cooking rice
I have a Sunbean Instant Streamer model 4710... I just wash the rice, add it to the bowl and add 1 cup of rice to 2 cups water. I fill the the bottom of the streamer to the max line and turn the steamer to 50 minutes.. The rice comes out great in my streamer this way
Sep 08, 2007 | Sunbeam SUN-4710 5-Cup Rice Cooker
Hitachi RD4056P 5.6-Cup Rice Cooker Logo
42 people viewed this question
Top Hitachi Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Hitachi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
