Question about Car Audio & Video
How many watts is my jl audio 2150 amplifier - Car Audio & Video
  • 1,940 Answers
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Mar 23, 2011
I got 2 old skool stage 2 rockford fasgates dvc 2000 watts a piece and 500 jl audio ampbut when connect them no sound comes out the subs what couldmy problem be
check the wiring on the back of the subs and try to hook them up different ways to see if the wiring is canceling itself out
Nov 26, 2009 | Jl Audio 500/1 Car Audio Amplifier
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Green light blinks slowly on my JL Audio 300/4 amp
Check your fuse at the battery. While AGU glass fuses "look" good, when you read the voltage AFTER the fuse, you can only be getting 5 volts or so. I can't tell you how many times I have seen this.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Jl Audio 300/4 Car Audio Amplifier
Will a jl amp e1200 kick a jl woofer 12w3v2 loud
yes a 1200 watt amp will do the trick.. the problem would be in the box the 12w3v2 sub needs a good size box and you should have one made for your car. and yes you will get the bass you want
Nov 16, 2008 | Jl Audio E1200 Car Audio Amplifier
2000 watt jl audio amp & car battery...
Make sure that you don't have any strands that would connect the remote lead to the constant +12 volts. Also make sure that your remote lead fromt the radio switches off when you shut the car off. If you don't have an aftermarket radio with a remote turn-on lead, tap into the ignition wire to the radio. Let me know what kind of car you have and I can point you in the right direction to get the right wire. Good luck.
-Andrew Hawkins
Apr 08, 2008 | Jl Audio 1000/1 Car Audio Amplifier
JL 1000/1 Amplifier
mine did that. i cleand the battery wires and hook ups now it works fine.
Jul 24, 2007 | Jl Audio JL1000 / 1 Car Audio Amplifier
Car Audio & Video Logo
456 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
