Question about Cameras
Kodak P712 - when camera is turned 'on', it will go thru start-up sequence, turn it self 'off', then restart, go 'off', restart, go 'off' and eventually stay 'on'. Are you familiar with this problem. I am using this camera professionally, it is perfect for my requirements and I would prefer to have it fixed rather than replaced. Bill Raymont 330-305-1916 raymo@sssnet.com
  • 6 more comments
  • raymo10 Aug 03, 2008
    As I said I use this camera professionally - I have done the basic trouble-shooting, including battery testing, heat and cold soaking etc. I would appreciate an'expert's' opinion. Thanks
    Please refer my question to a technician who understands my problem. Thanks
    I don't believe these suggestions apply to a Kodak P712
    'proton' and the last person' ideas sound logical. any ideas for repairs NOT KODAK? thanks
    Can I have the BIOS fixed somewhere other than KODAK ?
    Repeat; can I get the BIOS serviced somewhere other than kodak?
    Geemarie good advice, I'll go back to block one - but do you have any suggestions for repair stations other than kodak? thanks
    I think I have a 'dead horse' , thanks for your suggestions.
  • 876 Answers
Try this:
Turn off your camera.
Remove the batteries from your camera and have a close look at them.
The correct battery for your camera is Kodak rechargeable Li-lon battery 1700 MAh.
I do not have the same camera, however, I own 10 cameras and I believe this to be a POWER problem, so either you do have the wrong batteries or they are not fully charging for some reason. Batteries can look exactly the same but not be powerful enough to run your camera. You seem to be knowledgeable, but it never hurts to look at the basics. I am a photographer also and sometimes I just don't get the small things right.
Good luck
Posted on Aug 03, 2008
  • Cameras Master
  • 19,396 Answers
Test it with alkaline batteries, if you are using Kodak rechargeable battery the battery must be in need of replacement.
If battery is ok usually is a stuck lens gear, in this case you will need to go to a repair shop to have lens barrel opened and fixed.
  • 10,594 Answers
Kindly let me know about its Lens, does it open and close in On-Off process? If yes, Lens mechanism has problem and its not providing "Initialize" signal to syscon of camera thats why Syscon IC keep trying it On-Off. Its my technical openion.
    Guru:
  • 1,894 Answers
I would suggest you to flash the camera memory once.
then reinstall the camera software. and then update the firmware.
this will help you sort out the problem
    Brigadier General:
  • 6,966 Answers
Cameras not my field, however, on similar problems, it is often a problem with the battery and the camera sensing weak battery. Though the battery maybe charged fully, as said, the camera senses otherwise. In most instances, corrective action requires that the battery terminal contacts of the camera be cleaned. Sometimes, it would help if the terminals are scraped and made sure to be conductive. At other times, the terminals/pins have to be bent a little to put more pressure on the batteries.
Should the above be not corrective, I am sure others would be along shortly to address your concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 1,183 Answers
Hi Bill,
The problem with the camera is that the BIOS, ie the onboard sofware needs to be updated. The same can be done at any Kodak authorised repair centre.
Thanks
Mandeep
  • 120 Answers
Have you tried a different set of batteries?
that may cause this problems sometimes.
and also use a Dc input and check if the camera starts
Won't turn on
Maybe Powerswitch problem. Go here and read the solution:
http://www.dpreview.com/search/forums?query=p712+power+switch&forum=1011
Otherwise suspect battery and/or contacts
Jan 17, 2014 | Kodak EasyShare P712 Digital Camera
The Kodak P712 turns off and then on when I try to use it.
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 15, 2009 | Kodak EasyShare P712 Digital Camera
Kodak P712-With a freshly charged battery in the camera,the camera keeps turning itself on and off continously. Is this a camera or battery problem?
Hi
This is a camera problem from the operation unit. If the camera is not fallen on the floor or something else the flexfoil has conducting wrong and a reset with on and off switching occurs.
Apr 15, 2009 | Cameras
Kodak p712 shuts of and lens retracts
try resetting the timer to shut off the camera after a period of inactivity to a longer time. It seemed to work for me
Apr 06, 2009 | Kodak EasyShare P712 Digital Camera
Kodak easyshare p712 has problem in the on/off switch. When I turn the camera on, it will come on, but then will shut itself off, then turn itself on, then off again, etc. If I find just the right place in...
push down hard on the power switch when you turn it on,mine is bad enough that it doesn't turn on,If i push the switch down hard when i turn it on,it always works fine. Hope that helps,P Waters
Mar 28, 2009 | Opteka (OP-HD2W-P850) for Kodak Easyshare...
Kodak p712 restart
SOME OF THEM YOU GOT TO PUT ON MANUAL FOCUS TRY THAT AND SEE
Jan 21, 2009 | Opteka (OP-HD2W-P850) for Kodak Easyshare...
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
