Question about Lakewood Oil-Filled Electric Radiator Heater
Doesnt get hot - Lakewood Oil-Filled Electric Radiator Heater
The switch is probably bad. If you have used this heater for more than one season, then all that you can do is replace it. I have gone through about 6 of the Honeywell heaters through the years and Honeywell will not repair them after the warranty has run out. They only cost about $40.00 so they are fairly easy to replace.
Posted on Mar 25, 2011
What causes vehicle to get hot with ac on and cools with ac off. no lost a-feeze,new clutch fan,thermostat and flush.
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 21, 2012 | 1999 Ford Expedition
I have a reostat type hot/cold control on my 02 bonneville, and it will not blow hot, always cold. please advise . . . . .
this sounds like the hot cold blend door is not working and is always stuck on hot, this is located on the heaterbox,you will need to locate by watching as you move all controls until you find the one that doesnt move, then remove it and turn door by hand and try to see if hot air comes out, you will need to make sure when the blower is turned on the door doesnt swing back you may need to hold as you test and then is you get hot air replace that one. hope this is helpful.
Sep 05, 2010 | 2002 Pontiac Grand Prix
My guage runs half way whike riding and climbs up to 3/4 some times is this usual the other day it went up to the light comming on.
it should sit around half, may get to 3\4 on a hot day riding hard, but should not get to light on stage.
Check the fan comes on when it gets hot
Check cap or renew
Check thermostat or renew
Change coolant\flush radiator
Check for leaks
pressure test coolant system
it may even be a problem with the sender for the temp gauge, if it doesnt seem hot and the fan doesnt start
Apr 26, 2010 | Yamaha FJR 1300 Motorcycles
Car doesnt start
check your map sensor
May 02, 2009 | 1992 Honda Prelude
Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Feb 24, 2009 | Ovens
Inside heat does not get hot enough
could be the temp blend motor not working. does the heat go from hot to cold or is the temp always the same?
Feb 01, 2009 | 2002 Mercury Mountaineer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Built in oven gets too hot
sounds like your thermostat is bad not sensing temp
Apr 19, 2008 | Ovens
Lakewood Oil-Filled Electric Radiator Heater Logo
50 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
