Question about Goodman Heating & Cooling
Hi, I had the same problem last year and the tech said the sensor needed cleaned. My furnace ignites and fires up and the fan goes on and then it shuts off and keeps repeating the same thing. I can't figure out where this sensor would be?
  • Goodman Master
  • 3,293 Answers
It sounds like the flame sensor if so it should be a rod by the side of the burner
Posted on Mar 23, 2011
Induction fan comes on ignitor wont ignite
If the igniter turns orange and the gas fires for only a second or two then your heat sensor needs to be cleaned with sand cloth, if it does not turn orange then your igniter needs to be replaced.
Jan 17, 2015 | Amana Gas Furnace 90% Afue 45000 Btu...
Ignition failure.
if furnace fires up then immediatly shuts off check the flame sensor. make sure it is sitting far enough inside the burner box and has proper continuity. if ur getting ignition failure without having furnace fire up, check proper voltage to hot surface igniter, continuity within igniter
Dec 05, 2013 | Heating & Cooling
I have a Dayton 3E437A furnace that does not activate the igniter or solen.
Try the flame sencor looks like a small rod this may need cleaning but if you jumped ou tthe pressureswitch then this will need to be replaced , check air filter is clean .
Oct 20, 2011 | Dayton Gas Furnace Heater
Turn main furnace switch on, combustion air fan comes on and main circulation fan comes on. About 40 seconds later the igniter lites, two burners closest to the igniter fire up and immediatly snuff out....
Hello, if all the burners are not firing up then they must be cleaned out, usually dirt gets in the crossover parts of the burner and the gas cant flow to all the burners and therefore the flame sensor will turn off the furnace for safety. Clean the burners out this should fix the problem.
Feb 25, 2011 | Heating & Cooling
Armstrong furnace ultra 80sx doesnt always lite on first try,service repair man replaced smartvalve,sensor and igniter he says its ok if it doesnt always lite on the first try ,sometimes it takes three...
Sounds like your gas valve is sticking. Your repair man is somewhat correct by meaning that the furnace will attempt to start 3 times before going out on "Lock-out". The furnace is reaching it's expected life and you will start experiencing more frequent issues with it. Check into some of the incentives to get a replacement with a higher efficiency rating. The newer units have greatly improved in performance as well as comfort.
Jan 13, 2010 | Heating & Cooling
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Main Fan won't turn off even with thermostat removed. Burner not
There is a chart with the wiring diagram and othere charts that will tell you what the 6 blinks are for. That should tell you what is wrong and what part you need. Sounds to me like the board has an issue or the gas valve is locked out.
Jan 10, 2009 | Goodman GDS81155CNA Open Flame Mid-Size...
Coleman furnace fan keeps turning off and on every 10 seconds...
clean your heat/flame sensor with sand paper or steal wool. If the sensor is dirty, it won't detect the heat from the flame and it shuts the gas off. Clean the soot and junk off the sensor and it should work fine. I have to clean mine every year. After spending hundreds of $$ every yr on tech calls..I figured out the problem and in 30 sec I'm up and running again.
Nov 10, 2008 | Heating & Cooling
Ignition failure after three attempts then sits for an hour.
try cleaning the burners and or adjust the distance the igniter is from the actual burner .
Oct 01, 2008 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
23 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
