Question about Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher
Smeg dishwasher (model ST663) won't run
After selecting any wash cycle dishwasher begins but after making sounds like it is running, the washer beeps and then stops after approx. 5 minutes.
When washer is the opened the Soak, Delicate & Bio En lights are flashing, the Intensive light is solid anf the Normal light is off. There is also no water in the washer after this occurs.
  • katykity2003 Mar 16, 2009
    my dishwasher washes then beeps constantly, and sounds like its trying to start... but it wint and dishes not getting cleaned
2 Suggested Answers
  • 19396 Answers
SOURCE: I have a smeg st663 that has the delicate and
Try first to reset the error follow the procedures below.
  • Hold down program selection button for up to ten seconds
  • Close the door.
  • After approximately 1 minute the dishwasher will advance to the end
    of cycle.
  • Turn off power from main circuit breaker.
  • Dry water inside the dishwasher.
  • Clean the filter unit (see Manual here, page 26 )
  • Apply power back.
3) If that does not work, please try the following procedure, it should enter diagnostic mode and reset the error.
  • Switch off the appliance
  • Turn the dishwasher back on.
  • Before any of the lights coming on press immediately the program button. Program button must be pressed 4 times within 4 seconds.
  • The two last program lights (normal and intensive) should start flashing.
  • Press again the program button once.
  • The Normal light will turn off.
  • The last light will keep flashing.
  • Switch off the appliance.
  • Wait 10 seconds.
  • Switch the appliance back-on.
If error is still there, then the problem is water pump malfunction. This will turn on second and third light from the left (light wash and regular wash)
The appliance cannot pump out the water. Check that the drain hose is not kinked or crushed and that the siphon and filter are not fouled. Check height of the drain hose at the back. Clean the drain well and filter located on the bottom panel of the machine. If the problem persists, contact the after- sales service. The pump must be accessed, freeing the hose connected to the pump from blockage, and testing the pump motor.
Note if lights are instead first (soak) and third (regular), then the problem is water inlet. In that case check pressure from the house, inlet hose. If that does not fix the problem, then the inlet valve and water level switch must be tested.
If lights are Delicate and Normal (the one with glasses and the one with dishes), then the problem is drain.
Posted on May 28, 2011
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ... > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ... > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Brand New Whirlpool Dishwasher won't start, can't change program eiether
Make sure the dishwasher door is firmly closed, press and hold the start pause button for about 5 seconds, this will clear the cycle, The try selecting a wash cycle and push start.
See if this helps.
Mar 04, 2012 | Whirlpool Dishwashers
I have a WD1 12C Smeg washing machine - when I open the door there is an awful smell reminiscent of stagnant water - the machine it self seems to be running OK I've put it on 90degress empty but still...
This will potentially sound odd, but run the 90 degree cycle again with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 07, 2011 | Smeg WDI12 Front Load Washer / Dryer
My smeg dishwasher seems to be permanently in wash mode. The light on the menu of settings no longer flashes, but permanently is on, and when I run a load it never stops. I hear the two beeps as if the...
You have a timer relay issue ,probable need a new board for it ,a cheap fix would be to time it and see how long it take to run full cycle and put a regulaer outlet timer on it or a alarm off your stove or what ever,save a couple of bucks
Feb 16, 2011 | Smeg STX2 Dishwashers
How much bleach do you add during cleaning cycle?
If the model number is correct, to run a "Clean" cycle on this model washer you need to follow these steps:
1. Make sure wash tub is empty and close the door.
2. Open the dispenser drawer and remove the plastic divider in the MAIN DETERGENT compartment.
3. Select the following options:
a. Select the POWER button.
b. Select RINSE/SPIN.
d. Select WARM/COLD water temperature.
f. Press EXTRA RINSE button 4 times within 5 seconds and the
will begin.
4. The washer will run a short sensing cycle for about 3 minutes.
5. The washer will beep 4 times and a code will appear on the front panel display.
a. If "Ab" (Add Bleach) appears - skip to step 6.
b. If "Rl" (Remove Load) appears - the door will unlock and you
need to double check the wash tub for any items. Close the
door when complete and press the START button.
6. Add bleach. If this is the first time running the clean cycle add ONE CUP of bleach to the detergent compartment of the dispenser drawer. If this is a monthly routine, add only 1/3 CUP of bleach.
These instructions are listed on page 18 of your owner's manual. If you no longer have a manual, yo can obtain a FREE copy at Just type in your model number under their "Manuals" link and you will find it listed in .pdf (Adobe) format that you can download or print for free.
If you have questions, please post back and let me know. I hope this helps you.
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher Logo
168 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
