Question about Creda C361E Electric Kitchen Range
Creda grill hi was changing elements in grill, but one of the live wires touched the back frame when i turned on the power with a big spark, i now have no power going to the fan or the grill elements.has something fused
    Scholar:
  • 160 Answers
Check the breakers at the breaker box. they probably kicked out. turn off, then back on. see what that does. (be sure the wires aren't touching any bare spots this time).
Posted on Dec 05, 2008
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Feb 11, 2011 | Ovens
How to change a grill element, cant mave the 2
Just had same problem, requires a short nosed Philip's cross cut screwdriver. I couldn't get them to turn either when using a cross cut with any length of blade beyond the actual cross cut part.The element screw heads are very shallow. Hope this helps,.
Apr 27, 2010 | Creda C362E Electric Kitchen Range
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
Hi - I have a creda solarplus cooker (48349) - I wish to replace the 8 bar grill element with a 4 bar grill element - can you please advise me of the steps necessary to do same - yours michael clancy
It’s basically as simple as:
Turn off the gas supply to the range.
Turning off the mains power to the range.
Remove the back panel behind the grill.
Remove the 2 power connectors to the grill element.
Remove the earthing wire to the element screw terminal.
Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your range.
Reconnect the power cables to the element.
Reconnect the mains power and recheck that the grill functions correctly.
Turn on the gas supply.
Oct 05, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Creda grill will not switch to oven when i shut the door
Model Number TGF334BCWF Gas Stove.....When I turn the burner on the top front right my oven is coming on without me turning the on. What is going on?
Feb 21, 2009 | Creda C362E Electric Kitchen Range
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
Creda C361E Electric Kitchen Range Logo
257 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
