I have a 96 acura 3.2 tl and is overheating and the fan is not working. When I put the air conditioning on the fan seems to kick in. I was wondering what I can do to fix it?
    Guru:
  • 683 Answers
Sensor on block, with no ac on the fan works from the temperature sensor, with the ac on it works from a relay.
Posted on Mar 22, 2011
96 acura tl 2.5 liter,short term fuel trim at negative 20 percent
Do a cylinder leak down test,for bad valves on #3
or head gasket,misfires for a reason
(Cam Worn ?)
Have to get rid of any misfires
If your taking out 20% your correcting for a rich condition,maybe
Some injector issues,old,need to be sent away for cleaning & flow
testing or replaced?
Drive it for 30 miles & add short & long term & see what you get
Exhaust Converter any good ?
Mar 25, 2014 | 1996 Acura TL Series
2000 acura tl ac heater fan wont turn on
my acura tl fan turn on when i turn on air conditioning why
Aug 22, 2012 | 2000 Acura TL
2007 MDX Air Conditioning Slow to Come on
I have a 2007 Acura MDX and its take forever for the air to get cold. Once it starts getting cold it work AMAZING, however waiting 20-30 minutes for the air to start is the WORST!
Jun 02, 2012 | 2007 Acura MDX
2000 Acura TL overheating at low speeds with A/C on
Before ordering or installing fans I would buy and change your Coolant Temperature Senor on top of the engine block. It plugs in to the ECU and tells the fan when to kick the fans on. If that does not work you also have a temperature on the bottom of the radiator, known as your fan switch.
Jul 23, 2010 | 2000 Acura TL
My Acura 2003 tl 3.2 stop working all both system fan and air conditioning.it worked well yesterday.
it is probably the blower motor resistor, had the same problem on 2003 CL Type s, the fans for the A/C and heat just stopped working was the symptom . The part is only about 70 dollars.
May 11, 2010 | 2003 Acura 3.2TL
Whar weight oil should a 96 accura 3.2 tl use?
use a good 5w-30 oil, and replace the filter
Nov 26, 2009 | 1996 Acura TL Series
96 acura tl 3.2l is overheating+signals wont work
Start with the easy one (hopefully). You probably have to replace your turn signal flasher. It's located behind the dash, driver side of steering column in the relay block (just pull out to remove).
Your overheating problem: Are you losing coolant, or is the car just running hot? Any leaks, puddles?
Check the cooling fans to make sure they are kicking on as the engine temp rises. If not, you may have a bad switch that is not telling the fan to go on. If fan(s) are operating ok, check the thermostat. If it isn't opening properly, it could be the cause of the overheating. If you have a leak in the system, then when it gets too low, it starts to overheat. Many possibilities, So, let me know the answers to the above so I can help further if needed.
Jul 22, 2009 | 1996 Acura TL Series
96 Acura TL is over heating
check that both fans are on.one is the a/c fan and goes on and off with the a/c.make sure there is no air in the system,and change the thermostat
Jul 07, 2009 | 1998 Acura TL
Air cinditioning blowing from cold to hot air
need to check ac fan or fans ,are they working? if not check fuses and fan relays,,,,,and fans (hot wire the fan to see if it/they work
Jul 05, 2009 | 2000 Acura TL
96 Acura 3.2 overheats after replacing the top radiator hose.
try to bleed the cooling system. the system might have air in it.
May 28, 2009 | 1996 Acura TL Series
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
