Question about Northstar Pressure Washer 3000 PSI
Hi, I have a qusstion. ?Can you run a pressure washer without it being hooked up to water? Thanks
  • 604 Answers
The short answer is "no" and I have to ask, why would you want to, if you are thinking that you could use it to provide high pressure air to blow stuff off your deck, it won't work, the pump requires liquid in order to get enough pressure to push the water at high pressure
Posted on Mar 23, 2011
  • 2 more comments
  • dslangton167 Mar 23, 2011
    the reason i asked was to see if the engine ran. I was looking at a unit to buy , we live in minnesota so water hook up out side is kinda tuff. I wanted to see if the honda motor ran
  • Keith Brown
    Keith Brown Mar 23, 2011
    Well in that case you can run it briefly, but i wouldn't advse runnig it for more than a minute or two
  • Keith Brown
    one more thing, you really need to hook it up to a water supply to see if it works, otherwise you may just buy a running motor with a pump and compressor that doesn't work.
    Thanks for the advice.
    Dave
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
Jul 22, 2014 | Annovi Reverberi Garden
Have a tradesman h120 pressure washer..it will not spray any water at all.. pump is workig?
If the pump was run without having the supply hose hooked up and water to the pump before turning it on, you have destroyed the seals and they need replacing.
May 24, 2014 | Garden
Does it hurt a pressure washer to run hot water thought it went they hook up the water for outside to hook it to the hot water i did not no it and i hook it to the pressure washer
most pressure washers have packings that can sustain a temperature of 140 degrees although it as strongly not recommended since the pump head heats up when in bypass mode(triggergun closed)best rule for pressure washer is never leave the trigger closed for more than 3 minutes even with a thermal sensor:):)
Jul 31, 2013 | Karcher 2500 PSI Pressure Washer
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
May 31, 2010 | Northstar Professional Series Pressure...
When pressure washer engine is running and hooked to water supply, there is no water spray with trigger is depressed
Hi Have you checked that your nozzle in the lance end is not blocked. Please try this and then try without the high pressure hose attached.
Oct 27, 2009 | Karcher 2500 PSI Pressure Washer
Is it OK to run a washer without water
All you can test without water, is the spin and pump functions..
The heater and the wash action will not work without the correct amount of water in the washer.
Hope this helps.
Plz rate my solution.
Thanks
Jan 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Northstar Pressure Washer 3000 PSI Logo
75 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
