Question about Apple Computers & Internet
Palm t3 data to iphone - Apple Computers & Internet
    Master:
  • 525 Answers
Copy all the info from the palm to computer. Then hook up your iphone and tranfer the data.
Posted on Mar 23, 2011
Hot Sync deleted the entire calendar on both the handheld and the desktop. Contacts are still intact.
Hi Tracy,
Palm creates a backup file of your data so you can restore that file as long as you have not tried to sync your calendar again (that would create another backup file that would be blank.
Here is the link to a forum post that explains how to replace the data file with the backup:
Calendar data deleted from Palm Desktop can it be recovered
Feb 10, 2016 | Palm Tungsten T3 Handheld
Tungsten t3
Please use the free chat feature that palm offers. I am not sure of any other way to charge your palm. Here is the link. Scroll to the bottom of the page and you will see Palm Chat. Click on the Chat Now link and follow the instructions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t3/unlocked/supportservices/page_en.html
You might be able to find a charger on Ebay too.
Nov 18, 2009 | Palm Tungsten T3 Handheld
Error in Palm Desktop on PC
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Mar 21, 2009 | Palm Tungsten T3 Handheld
Pairing tungsten t3 with newer cell phones
I use Bluetooth to synch to my Sanyo cell phone, so I would think you could do the same. I maintain my Contacts in Outlook and synch with my Palm. I then synch my Palm to my phone.
1. Make certain that your Contacts (in Outlook, Palm Desktop, or whatever you use as your source to feed data to your Palm) contains ALL the phone numbers you want in your phone.
2. If, like me, you have a lot of contacts and a limited number (500 in my case) of contacts that can be stored on your phone, you will want to erase all contacts on your phone first.
3. On your Palm, go to Preferences
4. Select Bluetooth -- Bluetooth should be ON, Discoverable (Yes) and Connectable (Yes)
5. Turn on your Bluetooth-enabled cell phone -- I believe the range is 20-30 feet but I have not tested that. When I synch, I have them both on my desk because I want to see that it is working.
6. Select Trusted Devices. Hopefully, your Palm will detect the cell phone. When it does, add your cell phone as a trusted device.
7. Select Contacts on your Palm and use the pull-down menu to select Send Category.
8. Select Bluetooth
9. Select your phone
10. Your phone will probably indicate that it is receiving data. You should soon have all phone numbers stored on your phone without using a direct-connect cable.
Oct 01, 2008 | Palm Tungsten T3 Handheld
Palm T3 frozen, tried restart in hole, nothing?
take the battery off for 15 seconds and put it back again. you need to reboot your Palm at least once a week. goodluck!!!
Jan 31, 2008 | Palm Tungsten T3 Handheld
Data Lost - Palm T 3
  1. BACK UP YOUR PALM DATA! It is normally in C:\Program Files\PalmOne\XXXXXX, where XXXXXX is the first six of your Palm's User ID. If it is not there, the location can be found in Palm Desktop (Tools-> Options).
  2. Is the correct Data still present in Palm Desktop? If Yes, you're in great shape, it should sync back to the Palm after a hard-reset.
  3. If not, close Palm Desktop and look in the data directory. Some subdirectories (address, datebook, etc.) should have BAK files. If the BAK files are bigger than the DAT files, delete the DAT files and rename the BAK files to DAT. Restart Palm Desktop. Is the data there now?
If not, I am afraid you've had a learning experience. My Palm is synced to two different machines. One is running RAID-1 (mirrored drives), and both are backed up to tape weekly. Me? Paranoid? Naah...
Most people have to find out about backups the hard way.
Dec 02, 2007 | Palm Tungsten T3 Handheld
Lost Data
Sounds like you've wiped all your data. It's a good discipline to keep a regular backup of all your Palm files on the PC so that if this happens you can restore the last backup and re-synchronise. I have had several Palm devices, and all of them have corrupted files at some point.
Synchronizing Tungsten T3 with desktop or laptop
I recently re-installed my T3 program
What do you mean?
  • Did you restore your T3 from a backup on the PC?
  • Did you install programs on the T3 using the PC's "quick install"?
Is Palm Desktop showing the correct Contact/To-do/Calendar Data?
How are the conduits set up? (From Palm Desktop, select Hotsync->Custom)
Nov 15, 2007 | Palm Tungsten T3 Handheld
1 palm + 2 computers = successful hotsync?
Yes and.. no.
It is possible to have one Palm synchronized to 2 PCs (I do this with my T3), just make sure that you don't end up with any "overlapping changes" - items that change on both machines.
However, since Syncing takes a full backup of the Palm, having two completely different sets of data on two different machines is complicated at best. If you are are not careful you could lose all your info by accident. One way to get around this would be to put everything on on the T3 and use categories to separate work and personal items - which is what I do.
However, if you are dead-set on keeping all of your work stuff in one place and all your personal stuff in another, I would recommend that you get a second T3.
Sep 07, 2005 | Palm Tungsten T3 Handheld
Computers & Internet Logo
21 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
