Question about Canon PIXMA MP830 All-In-One InkJet Printer
Mp830 won't enter service mode even with the right combination of keys. ip5300 and ip5200 shows operator's error
SOURCE: Cant enter service mode
I almost gave up and bought a new printer. Then I discovered I could simply put a piece of tape over the censor area of the particular cartridge. The tape should go over the inset part, which is above the bottom prong which sticks out.
Posted on Dec 30, 2008
  • 68 Answers
SOURCE: How to enter ''service mode'' on Aficio SP C221SF Color MFP
this is priveledged information and kept away from non service personnel to protect both you and the device from unqualified access and possible damage.
if you have an issue that requires entering service mode please call for a ricoh tech this ensures that you are protecting the investment you have made in purchasing a ricoh device.
Posted on Sep 16, 2009
SOURCE: Unable to enter program mode for Sharp AR-C260M Copier / Printer
Solved the problem by switch on press #P Then * then C then *  then 14  This will then ask if to execute the action to clear the service code H5-01.
Will need to ensure that the fuser unit is not causing a blockage on the feed out path as this code is caused by 5 errors / misfeeds in the Fuser unit.
Posted on Nov 16, 2009
asabur
  • 102 Answers
SOURCE: I just need to know two things...Is the adj app
just download service manual you get it all function
Posted on Jan 09, 2010
pineworks
  • 4041 Answers
SOURCE: Locked In Copy Mode--Error Message: 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
Erro sc 551
You have a Fusing temperature problem.
Problably because the hot roller are crusted whith tonner and the thermistors cant read the temperature.
If you whant you can reset that error code. However, if the error appears again, i advise you to call tecnical assistence.
Try this to reset the code:
1-Press yellow key
2-On the key pad press 107
3-Old down the red key at least 3 sec.
4-Press 1copy SP
Exit all the way out to the copy window.
Turn the main swith off and on.
Feb 19, 2011 | Ricoh Aficio MP1600SPF Copier
I can't even fax from the machine with error code 6500 showing. Thus, it isn't just a printing problem.
Error code 6500 on the MP830 is for a PCI bus error. The Canon service manual suggests the remedy is to replace the Logic Board. That wouldn't be cost effective if you could even get the spare part.
Sorry I can't be of more help.
Jan 07, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Nov 13, 2009 | Sharp AR-C260M All-In-One Printer
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
I need to retrive the key operator code for a Aficio 1060/1075. How do I do this?
You cannot restore the key operator code for the Aficio 1060/1075. You can delete the code and then write new one .
Follow the instructions and will be easy.
1. enter the service mode.
2. To enter the service mode press one after other the follow keys on the control panel of the copier.
press the yellow key [ Cancel Modes] than press the number one after other [1]-[0]-[7] on the number keypad of the copier and than press and hold the red key [ Clear \ Stop] until on the touch screen do not appear the service menu after the service menu will appear press on the touch screen [Copy Sp] up in the right corner has a touch key [sp direct] press that key and press the follow numbers on the number keypad which are 7810 and then press "#' on the number keypad.
on the screen will appear "execute" press the touch button and than by pressing
"exit" several times you will exit from the service mode.
NOTE: "PLEASE DO NOT TOUCH NOTHING ELSE IN THIS MODE IF YOU ARE NOT A SERVICE TECHNICIAN BECAUSE BY PRESSING SOMETHING YOU MAKE SOME ERROR OR OTHER PROBLEM"
After clearing the key operator code you may enter new one.
If you need something else please ask
PLEASE RATE ME
Jul 15, 2009 | Office Equipment & Supplies
Error Code showing E000020-0160. Help soon.
Your error code relates to your yellow drum unit. It probably need replacing. Enter service mode by pressing - the additional functions key (key with star in it) then 2 and 8 together - then the additional functions key again. This will bring you into service mode. Now select 'COPIER' and then 'MISC' this will then list the drum life in percent for each colour drum unit - you'll probably find that it is well over 100%. Maybe even 200 or more. In any case this is just an indication because the drums can even last 300% at times. You'll probably need a new drum unit.
May 09, 2009 | Canon imageRUNNER C3200 Copier
Mp830 fax problem
Got an answer from Canon NZ:
1. Press the red Stop/Reset button and keep it pressed.
2. The 'Alarm' light will flash - count 12 flashes.
3. The screen on the Canon will show 'SERVICE MODE' and something #1.
4. Press the right arrow key twice to bring up FAX TYPE #3.
5. Press OK to check the country - mine showed Australia when it should have been New Zealand. Scrolling with the arrow keys shows the countries available for your machine.
Jun 19, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon ip5200 Service Error 6A00
This might have something to do with canon's absurd print cartridge limitation agreement.... where the print cartridge will only print for a certain limit and then locks
Jun 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
52 people viewed this question
old marine
old marine
