Question about Necchi 3101 Mechanical Sewing Machine
Necchi sewing machine problem
Sewing machine wheel just turnes and does nothing to move needle
  • larcher Aug 03, 2008
    sewing machine wheel turnes and does not move needle
  • Necchi Master
  • 7,365 Answers
Needs to be serviced
Posted on Jul 31, 2010
  • 136 Answers
See if you can turn the small wheel which is inside the larger wheel on right hand side of machine. if no the machine has bind and refer to manual to see how to remove bobbin case, race front and hook, try again to turn, should be free. If the little wheel turns try tighten it inside big wheel this should fix it.
Posted on Sep 12, 2009
  • 69 Answers
Tighten hand wheel
Posted on Apr 30, 2009
Necchi automatic supernova Julia; zig zag won't engage
There is a lever for positioning the needle bar. When you move the lever to the left middle or right , the needle bar too should follow the same. Try to do that. If it doesn't follow the lever and stays at one end, that means the machine needs to be oiled. Not like most sewing machines Supernova swings the bottom rod too to left and right when Zig Zag is engaged. I recommend to spray some WD 40 first, to inside of top and bottom side of the machine , and later to apply machine oil to every moving joints.
Feb 20, 2016 | Necchi Sewing Machines
I have a Necchi 3101FA. I am trying to figure out how to release the stop motion knob so that the needle won't run while I am trying to thread the bobbin. Does anyone have any idea?
the hand wheel is a 2 part device hold the outer wheel and release the inner part by turning it toward you . wen done winding bobbin retighten the wheels together .
Aug 26, 2015 | Necchi 3101 Mechanical Sewing Machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Aug 03, 2014 | Necchi 3537 Mechanical Sewing Machine
Necchi supernova manual
Most sewing machines can use a double needle, the one with the single mounting shank and it turns into two needles.
MAKE sure you have Zig Zag needle plate installed to accomodate the double needle.
Turn hand wheel slowly to test then use thread and fabric and turn flywheel by hand to test sew.
Jul 19, 2014 | Necchi Sewing Machines
Very old Necchi sewing machine - sews in place
sounds like the feed dogs may be down or not working. Watch to see if the little teeth are moving under the pressure foot when you stitch( try to run unthreaded and with foot up no fabricto check) May be a button to turn up the feed dogs.
Oct 27, 2008 | Necchi 3101 Mechanical Sewing Machine
Necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
May 01, 2008 | Necchi 3101 Mechanical Sewing Machine
Necchi 3101 Mechanical Sewing Machine Logo
287 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
