Cant access OSD Menu on my ViewSonic N4060, upper left message says its bloqued
  • Televison & ... Master
  • 5,428 Answers
The OSD lock can be toggled on and off by pressing and holding both Vol+ and Vol- on the side panel of the TV. On some of the older Viewsonic models, you have to hold the buttons for 10 seconds. I'm not sure how long you have to hold the buttons for the N4060.
I hope this helps.
Posted on Mar 22, 2011
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
Hand-me-down N2750W
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Mar 21, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
I am getting many times osd lock problem i am getting irritating so please give solution for unlock the osk lock on monitor.... or sometimes repeatedly blinking the main menu on the...
Nov 26, 2010 | ViewSonic E70f 17" CRT Monitor
Respected sir/ Madam please give suggestion to my
To unlock the OSD lock, Press and hold the menu button for 10 seconds then the menu will appear
Jun 29, 2017 | ViewSonic A90f+ 19" CRT Monitor
How to get rid of osd lock which appears frequently on screen?
Hold the MENU button for ten seconds to unlock or lock the OSD.
This information is from your manual for the L194WT:
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 08, 2010 | ViewSonic Computers & Internet
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
OSD Lock
OSD lock is a feature which locks the OSD. It can be enabled or disabled by pressing the menu button for 10 sec. It is the lock which locks the On Screen Menu for changing the menu settings.
To unlock press and hold the menu button for 10 sec.
Thank you Sir, Have a nice day.
Sep 23, 2009 | ViewSonic E70f 17" CRT Monitor
At the centre of my viewsonic monitor model:E70fB a message in blue coloured box that"osd lock"and its blinking continously its irritating me
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This might unlock your OSD menu and remove that message from your screen. regards
May 14, 2009 | ViewSonic E70fb 17" CRT Monitor
OSD lock - I think
This is for Viewsonic LCD, but it's probly pretty similar for you...
OSD and Power Button Lock Modes
OSD Lock This mode locks all current control settings and prevents access to
the control menus until this mode is unlocked.
? OSD Lock: Press and hold [1] and the up arrow  for 10 seconds. If any
buttons are pressed the message OSD Locked will display for 5 seconds.
? OSD Unlock: Press and hold [1] and the up arrow  again for 10 seconds.
raj, rajkumar.ranju@gmail.com
Jul 22, 2008 | ViewSonic E70f 17" CRT Monitor
Reparacion de monitor acer 7134t
I have Viewsonic 17" Inch crt Monitor, it's working good. But now this is blinking blue colour message tht message osd lock, so hardware friends telling that is Operating system problem, some friends telling no that is Monitor problem, so really i don't know friend... so what can i do? pls give me good solution frnd...
Thank You.
Tamil Selvan.V
tamilselvan_77ips@yahoo.com
tamilselvan77ips@gmail.com
09787811833.
Apr 23, 2008 | Computers & Internet
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
