Question about Sony Playstation 3 (PS3) Console
Hi i have a problem on my ps3 slim it shows cannot start the correct hard disk was not found can you please help me
    Novelist:
  • 102 Answers
Some possible solutions, from easiest to hardest:
-Unplug the PS3 from it's outlet, then replug it back in.
-Restore the PS3 to it's default settings by turning off the console, then pressing and holding the power button for around 10 seconds (it'll beep a few times).
-Remove the hard drive from the console, then put it back in. Here's a detailed guide, but basically you use a screwdriver to remove the bottom hard drive panel, then pull the metal handle to pop it out. You don't have to remove it from it's frame; once it pops out, just put it back in.
-Try the PS3 Safe Mode, options 2, 3, 4 and 5 (3 might delete data, 4 and 5 definitely will).
-Replace the hard drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives (5400 or 7200 RPM). They can be found online at any computer parts website; for example, Tigerdirect.
Send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe). They take forever to send it back though.
Posted on Mar 23, 2011
Ps3 cannot start. the correct hard disk was not found
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk, put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says. Also you may have to replace your hard drive ,not very expensive good luck
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
Iturn on it says cannot start the correct Hard disk was not found
Open up your ps3 on the right site with a small flat screw driver.
Turn out the blue screw with a small cross screw driver, slide the hard drive to the left and pull it to warts of you, note it is a 2'5 inch sata notebook harddrive.
Hook it up to a pc or mac to run a diagnostic check on it to see if it is crashed, by the way you're able to tell by the sound it makes if it crashed.
Aug 28, 2009 | Sony Playstation 3 (PS3) Console
Cannot start. The correct hard disk was not found.
As with many of us current and former PS3 owners you need to have your HDD (hard disc drive) replaces. sorry
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
PS3- cannot start. Correct hard disk not found.
when your ps3 is standing upright the tall way tip it over and look at the bottom there should be a plate that says something about the hard drive. get a flat screwdriver and pry on the right side of the plate. The hard drive is directly behind that plate and is secured by a blue screw. take out the screw and flip out the little u shaped handle and slide it to the right and pull out your hard drive. Try blowing out all the connections and putting it back in hope this helps
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
Ok there is only 1 500gb drive that is compatible with the ps3 and thats the Samsung spinpoint, go here to find out
http://www.1800blogger.com/2008/08/31/how-to-install-a-500gb-hard-drive-in-your-playstation-3/
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
It says Cannot start, The correct Hard disk was not found
hi i had this problem and all you have to do is replace your hardrive it cost money but its way less than buying a new ps3
Apr 20, 2008 | Video Game Consoles & Games
Hard disk problem
I have a problem with ps3 Cannot start the correct hard disk was not found. can any one help me on this.
Dec 31, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
