Question about Nextar W3G-01 GPS Receiver
Hello, It will turn on but the system is frozen? It has worked fine for us up until this weekend...
    Sergeant:
  • 296 Answers
Overheated. Replace motherboard.
Posted on Mar 22, 2011
Frozen screen
It needs to be rebooted. Turn off, by holding off button down. Then once it is completely off, then turn it on, BUT when you go to turn it on, keep on button depressed, all the way until it turns on and then some for about 15 seconds, now you just rebooted system. Let me know, mike
Jul 27, 2011 | Tomtom GO 300 GPS Receiver
No water to water/ice dispenser
My old GE stopped working not too long ago too. Same thing, water to the back and no further. I replaced the pump ($25) and it worked fine. I found the pump at an appliance repair shop, they ordered it for me, a few screws and such and it worked! Good luck.
Mar 29, 2009 | Frigidaire FRS26ZSG
The furnace is blowing warm air even if the thermostat low.
The only thing that tells the unit to come on and off is the thermostat so I would definatly say it is it. When you turn the system back on, does the a/c run normally? If it does, then it's the problem with the heating side of the tstat. Also, does the fan come on when you put it to on and then turn of when you switch it back to auto? If it does, then the system is working fine, its the t-stat. Let me know if you have any more problems.
Mar 23, 2009 | Intertherm P3RA-048K Air Conditioner
Freezer Does Not Stay Frozen
one of the hardest things to diagnous is food defrosting in the freezer. i found out the hard way about 35 years ago, but not until i banged my head against the wall a few times. the problem was the customer didn't have enough food in the freezer as she was a weekender.frozen food needs frozen food to keep the food frozen confused? so was i . every time your refrigerator goes into defrost( usually every 8 hours) a heating coil comes on in the back of the freezer. if the freezer is not full enough this heater can raise the temperature in the freezer to 40 degrees which will soften the food and melt the ice considering the time it takesto refreeze the food. i never forgot that service in fact i can see it in my head right now.. try this cure first let me know
Feb 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer/Rerigerator not cooling
defrost system has failed. for a temporary repair, melt ice off with a hairdryer but dont heat up any stats mounted on the pipework.
check continuity thro the defrost heater and thermal fuse in series with heater with a multimeter.
if both of these are ok, points to a module fault
Aug 30, 2008 | GE Refrigerators
Unit will not turn on
Hello sympleman,
What you are describing may very well be a result of the battery going bad. The internal battery in your GPS receiver does have a limited lifespan. It is normal for the amount of operating time between charges to gradually decrease until eventually the battery pack does fail.
Unfortunately the battery does not appear to be replaceable by the user. To get the battery pack replaced you can contact Garmin directly. Their website is http://www.garmin.com.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 23, 2008 | Garmin Quest 2 GPS Receiver
Frozen on.
Problem resolved. I just let it sit until battery went down far enough for "Battery" alert to come on screen.
From there I put a charge on it and everything works fine now. Probably I should have kept it charged up.
Nov 28, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Nextar W3G-01 GPS Receiver Logo
127 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
