Question about Sony Cyber-shot DSC-W50 Digital Camera
Camera records regardless of mode setting.
My Sony dsc-w50 has developed a strange issue. Regardless of the shooting mode I select whenever i take a picture the record light comes on. When i download the picture it has taken 40 frames in one picture. Has anybody seen anything like this before?
  • 797 Answers
Possible stuck button on the camera.
That may be due to some kind of juice, or drink or some such thing getting into the button area.
It may also be due to the fact that the trigger button is not releasing quickly enough.
This will need repairs, and may be more than what you want to spend. For that reason selling it as is or for parts on a site such as Ebay may be your best out.
Posted on Aug 03, 2008
Sony Cyber-Shot DSC-P73 Digital Camera suddenly flash is not working
The flash may be broken.
If not these are the flash settings on the camera in case a different flash mode has been set accidently.
Set the mode dial to [camera icon], and press [up arrow] on the control button repeatedly to select a flash mode.
The flash mode has the following features.
No indicator (Auto):
The camera decides to use the flash based on lighting
conditions. The flash will be used when
there is not enough light or when shooting a
subject against a light source.
(Forced flash):
The flash will be used regardless of the amount of ambient light.
(Slow synchro):
light. In this mode, the shutter speed is
slower under dark conditions, so you can
clearly shoot a background that is out of the flash-lit area.
(No flash):
The flash will not be used.
Oct 18, 2014 | Sony Cyber-Shot DSC-P73 Digital Camera
My sony DSC H10 cameras flash isnt working what could it be?
If the flash is not functioning, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
This should resolve the issue.
Thanks for using FixYa.
Jan 27, 2011 | Cameras
I cannot find the burst mode on my camera, the only thing that my camera said was cannot use burst mode with flash
In burst mode, the Camera will be taking multiple images. Flash can only spark once to get enough light. If the Flash is enabling in the multi burst mode, it will loose the battery power as well as not give the correct images. Hence, by default regardless of manufacturer, the flash cannot be used in multi burst mode.
I hope you understand my concern. Thanks.
Jan 24, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My camera s flasnmode did not work it happaned when my camers power on for a long time how to fix that flash mode ?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
Jan 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Flash doesnt operate on any flash mode
Follow the steps below to check if the issue can be resolved.
Check if the battey is fully charged.
Charge the battery in the Camera and check if the flash charge lamp is flashing. Once the Lamp goes out the Flash in the Camera gets charged.
Once it is charged, press the Up Arrow button in the Camera continuously to select the Forced Flash which will strobe regardless of the surrounding brightness.
Make sure that the Camera is not in TWILIGHT or LANDSCAPE scene selection mode.
Make sure that the MODE and REC MODE is not set to BURST3 or BRKTG from the Menu settings.
Change the REC MODE and SCENE SELECTION Mode to enable the Flash in the Camera.
If the issue persists, service may be required.
Thanks for using Fixya Support.
We wish you a happy Christmas and New Year!!!
Dec 23, 2010 | Sony Cyber-Shot DSC-S85 Digital Camera
No matter what picture setting is selected the camera, Sony DSC-W50, it will only take video. Does anyone know how to fix this problem? Thanks
I think mode selector dial is not working in your DSC-W50 that is why camera is set on video mode.
Replace mode selector dial as mentioned in below image, part number is...
1-479-584-11 CONTROL SW BLOCK (SW110T) (for SILVER color)
1-479-584-21 CONTROL SW BLOCK (SW120TB) (for BLACK color)
Available in Part Store.
Thanks.
Oct 20, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Cybershot dsc-w50 records movies instead of pictures
I had the same problem with my camera.  I found that changing the mode from Multi Burst to Normal allows the camera to take normal pictures.  Go to Menu and scroll over to Mode, then select Normal.
Jul 10, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
I CANNOT TAKE PICTURES WITH MY CYBER-SHOT DSC-W35... HELP!!!
Check Mode-Dial of camera. it has set on Movie mode. Select Auto mode to take snaps. this idea is for cysber-shot camera.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Record Mode
I had the same problem and you go to menu then REC mode and make sure it is on normal, mine was on multi burst and thats why it was recording on every setting. Hope this helps :)
Apr 29, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
