Question about Refrigerators
Hi there my maytag is fully working fine ,for a few days then it gos into deforst, ice on bk of freezer inside ,but soon as it starts to ice up it shuts off ,thinking it needs it defrosting,works fine for 2 weeks then it started again auto defrosting, please help cos its costing me hell to keep buying new frozen food ....love u lot for ever if u lot counld help me , i can easy fix it ,just need a gide ,thanks loads paul ...maytag gc20c7c3e. i had a man come out and he said it needed a new defrost wheel , what u recon ,would he be right or he having me on .thanking u x
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
22yooper
  • 828 Answers
SOURCE: Kenmore 77563 Installed last week and freezer defrosted all the food
The refrigerator & freezer operate using the same system. One system. Your still covered by the warranty and I would suggest calling the installers or store from which it was purchased. The problem may be a faulty fan switch .
Posted on Apr 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Side by Side (3 yrs Old): Freezer iced up, refrig not cooling
Most GE defrost problems are bad defrost thermostat and defrost heater.
It requies removing the back wall panel on the inside of the freezer to access the parts.
Posted on Mar 17, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GC2224gek admiral freezer keeps defrosting
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Mar 28, 2009
Testimonial: "Thank you for your response. It was the circuit board that was faulty just over a year old. It was replaced just before I saw your email. "
  • 32 Answers
SOURCE: Smeg fridge which keeps freezing and doesnt auto defrost
the defrost timer or the defrost heater needs replaced
Posted on Oct 20, 2009
Testimonial: "Thanks very much!"
I have a Whirlpool MFI2266AES and few days ago the ice/water dispenser stopped working. At the same time the freezer temprature started to rise and the temp alarm started beeping. The freezer fan was...
Hi, it sounds like your having problems with the thermostat ,they don't last for ever. I had the same problem with a fridge freezer and i got the temp thermostat replaced. You have a modern unit and you may have two but i think you have to look at the ice cube maker side first. Check that the water supply is getting to it.Have a look at your manual or you can type in the make and model and look up online .
Mar 06, 2014 | Maytag Refrigerators
Freezer apparently wont defrost because it has that dry ice look. freezing fine
some times our equipment need rest !!! remove your food , unplug for at least two days, clean inside.after two days plug back
Mar 12, 2012 | Maytag MFD2560HES Bottom Freezer French...
Freezer works fine on my Maytag side-by-side refrigerator, but refrigerator is not cold enough, there is is ice accumulated inside the vent between the freezer and the frig., specially on humid days.
Defrost your fridge with a blowdryer in the freezer after you remove the freezer back panel. Get the ice out of your exhaust pipe going to fridge. Your evaporator fan should be running, either your defrost heater is bad or your defrost thermostat is bad. I ussually replace both. Good luck rate me if I am correct.
Aug 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Full of ice, no deforst , I change the timer and it seems to work, but after somo days start again, the model is WRT18DKL , i think is the termosthat but i need to know how to check it.
Hi, You will need to check continuity on the bi-metal switch and it needs to be tested while cold. If the bi-metal has an open circuit, it will need changed. Remove the rear inside panel of the freezer and locate the bi-metal switch at the top of the evaporator coil.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 11, 2009 | Whirlpool ART535 Top Freezer Refrigerator
Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
Jun 30, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Plz help refrigerator not working properly after transporting it
time to get a new defrost timer or heater element the ice is causing most of the issues. if the freezer is staying cold then there is a fan that blows the cold air into the fridge side that could be out.
Apr 27, 2009 | Refrigerators
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
