Question about Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive
Tengo una compactera dvd samsung rw combo disc rewritable pero no me deja grabar dvd si cd
peping
  • 99 Answers
SOURCE: Samsung TS-H492 CD-RW Combo
are you using a single IDE cable with your H/Disk? if yes! check, the jumper connections of your CD-ROM,maybe the are both in the master position ,change the jumper of your CD_ROM to slave position.or use another cable for your CD-ROM.if doe'snt work go to BIOS SETUP,set the settings to default SETUP.then restart your PC.
Posted on Mar 12, 2008
MyTechGuru
  • 93 Answers
SOURCE: my samsung dvd rw combo is not reading any DVD
To work around this issue, open Control Panel, and then follow these steps to configure the DMA/PIO settings for a controller: 1. Click Start, click Run, type devmgmt.msc, and then click OK. 2. Expand IDE ATA/ATAPI Controllers. 3. Right-click the controller that you want to configure DMA/PIO settings for, and then click Properties. 4. Click the Advanced Settings tab. 5. In the Transfer Mode box, click either PIO Only or DMA if available
Troubleshoot DVD problems loadTOCNode(2, 'moreinformation');
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc
Posted on Aug 13, 2008
jepito
  • 216 Answers
SOURCE: TSST corp CDRWDVD TSH492B - DVDCD-ROM drive not working
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Posted on Dec 30, 2009
roy_gv
  • 107 Answers
SOURCE: I have a Samsung TS-H492A/RSWN CD-RW/DVD-ROM
let me make it clear, you said COMBO? combo drives are only CDRW and DVD ROM not CDRW and DVDRW, so it only burns CD and not DVD, it burns CD but it only read DVD.. clear
Posted on Mar 25, 2010
chromapr
  • 267 Answers
SOURCE: my samsung octo edge cd-rw/dvd-rom combo drive
If you do not have a disk with drivers go to the manufacturers web site and look for support or downloads to get the divers. save them to a folder you create on the c drive or go the driversone.com and put the info of your drive in and it will direct you to drivers then save them to the folder. Next you go to system icon in contol panel and then to hardware then device manager. look for cd/dvd drives and choose your drive then right click on it either disable it or reinstall the driver. If this helps please reply as this helps me continue to answer questions here and good luck
Posted on Apr 29, 2010
No me carga el juego monster world
a un amigo no le carga el juego...le aparece "Bad Request
Your browser sent a request that this server could not understand."...que se puede hacer?.. ya formateo la maquina e instalo todo de nuevo pero no hay caso...por favor espero una respuesta gracias!!
Oct 29, 2012 | wooga - world of gaming Monster World
Tengo una cannon power shot sd600 digital elph, en ella tengo 15 fotos y dos videos de 2 minutos cada uno la memoria es de 500 mb, pero el display dice memoria llena y no me deja sacar fotos ni capturar...
¡Hola!
Bienvenido a Fixya. Posible que sus videos y fotos se guardan en su memoria interna no en la tarjeta SD / tarjeta de memoria. S?lo tienes que seleccionar la tarjeta de memoria de dolor o guarda sus im?genes.
Gracias por usar ou Fixya,
seancarlisle
May 13, 2011 | Canon PowerShot SD600 Digital Camera
Hola, tengo una impresora canon mx320 "error de impresora 6000"?
Encontre soluciones, pero estan en ingles. Aqui te las dejo.
Solucion 1
Solucion 2
Si estas no te sirven deja un comment y trato de ayudarte mas.
Feb 13, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
No deja grabar pues dice que el disco no es grvable
trata con otro disco CD-R o CD+R, si el que tienes es CD+R pues trata con el CD_R
Apr 30, 2010 | Panasonic DMR-ES10 DVD Recorder
HL-DT-ST DVD-RAM GSA-H55N cannot detect dvd disc
I have same DVD writer and I am facing the same problem. During R&D for such failure on google I came to know there are two different Laser Diodes for CD and DVD. CD read write is working for me. I think DVD r-w laser has some problems. I am currently looking for options to get the new laser diode. As soon I replace the diode and see my DVD writer working. I will upload the video to replace the diode for you all.
Dec 26, 2009 | LG GSA-H55N DVD-RAM Burner
Dvd-r or dvd+r or dvd-rw or dvd+rw
dvd-r Does not allow for menus
dvd+r Allows for menus
dvd-rw Rewritable disc that doesn't allow menus
dvd+rw Rewritable disc allows for menus
Sep 29, 2009 | Compaq (200356-001)...
Ibm 06p2525 alguien podra decirme como configurarla para que inicie desde el CD de instalaciã³n de XP pues en el bios, no viene opciones de arranque. Y ya probe con F1 hasta la F12 y ninguna me...
El disco de instalación y su programa que usa (¿windows XP home?) son muy diferentes y lo que usted quiere hacer no va a darlo ningún beneficio. Déjalo todo como se fué diseñado. Aunque si podría hacer esto el resulto estaría una computadora muy lenta porque se va a tener partes que mueven. En muy poco tiempo necesitarái un disco duro nuevo y un drive de CD-DVD. Tiene una mente muy inteligente, pero deja estas cosas en vivo. Déjame que te doy una precaución. No juega con la tarjete madre, porque es una cosa muy delicada, sino que no estás preocupado pagar cómo US $ 300- 500 dólares y labor de mano de igual, porque quemastes la targata madre. No tengo más tiempo explicarlo pero mantenga sus dedos fuera de esta cosa tan delicada. Muchas gracias para la consideración y opción de nuestro servicio. Mi nombre es Constantino )arzconst es mi contraseña interna con Fixya.com=
Jun 13, 2009 | Computers & Internet
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
My Samsung CD-R/RW TS-H292A won't open so I tried to flash the new firmware (TS04) using sfdnwin but I got an error now my cd writer is totally not working although device manager still detects it. What...
Well at this point you dont have much options try to flash it again but with a new flash file and do it in pure DOS (Not a Dos Box in Windows) you need to boot the system from a Win Win 98 cd or floppy. and then flash from there.
Dec 05, 2008 | Pioneer DVR-107D DVD±RW Burner
Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive Logo
65 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
