Question about Dryers
I have a Kemore series 90 dryer model number 110.60922990 with a non removeable back and I am trying to change the heating element...I dont see any way to get at the element..the back doesnt come off and doesnt look like you can do it from underneath..does anyone know where to begin with this issue? Is there any way to get some sort of shematics or anything for this model? Thank you for your time and attention.....
    Champion:
  • 239 Answers
The bottom panel will come off after releasing the tabs between the lower panel and the front panel. Once the lower panel is removed, you will have access to the heating element. The link below will take you to a breakdown picture of your dryer.
Kelly
Posted on Mar 22, 2011
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
My 600 series Kenmore dryer will tumble clothes but not heat-dry them. This happened during a too-large load, and it hasn't heated on any size load since then. I was thinking the heating element might...
send model number and also you'll need a meter to do some checks for me,i'll be happy to work with you but need model numberalso is it gas or electric,if the lint filter is inside you can do everything from the front.
Sep 21, 2013 | Dryers
Kemore dryer serial number 96292110 dryer turns and operates but dosent produce any heat
Your dryer innards look like this
Their is usually a flap you can remove to get to the element.
It slides out after you remove a screw or 2 These videos show how to get into the dryer:
Older model:
Newer model:
More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2011 | Kenmore Dryers
I have a Kenmore 90 series dryer.The only number
the door should have a sticker where it closes against with model and serial numbers as for the second part ck terminal connection to elements to make sure they are tight next shoot continuity of the elements limit switches thermal fuse elements will be between 9 and 13 ohms others should read 0
Jan 28, 2010 | Kenmore Dryers
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Where do I find the heating element in a Kenmore 70 series dryer model 110.96575100
the part number you will need is 279838 and you can get that at whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore Dryers
Dryer heating element
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
Replacing the heating element
  • take the back off and it is in the metal case on the right. here is some visuals.
  • the second picture shows the element pulled out of the canister.
  • some of the newer dryers don't require you to remove the canister; there will be 4 screws on the back of the canister to remove the element shown as red dots in the 3rd picture.
  • if these pictures don't match what your dryer looks like then give me the model number of your dryer.
Aug 11, 2008 | Kenmore 63942 Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
168 people viewed this question
Top Dryers Experts
Marvin
Marvin
