Question about Ovens
We have a westinghouse silhoutte four gas burner cooktop. It is run on bottled gas. We thought we'd run out of gas a couple of months ago and had to wait until now when we could afford to replace the bottle. We have since replaced the bottle and after several attempts to light the burners, we are struggling to maintain a flame. The flame colour is blue and we can smell the gas when it is turned on, but the burner fizzles out after about 30 seconds of being lit. Is there something you can suggest that we can do to fix this, or should a service call be made to our realestate agent?
  • Ovens Master
  • 43,501 Answers
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Mar 22, 2011
I have a 5 burner gas range and cooktop one burner on cooktop won't start
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 12, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Broken stove knob
simple flame sensors at fault eg thermocouples replace bad sensors and dsi box (direct spark ignition )
Apr 01, 2014 | Ovens
I have a whirlpool gas oven model # SF367LEKB and the oven will not ignite. You can hear the ignitor clicking but it will not light. The broiler and four burners work fine. This happened several months...
What you need to check is if the spark is strong at the bake burner.To do that remove the oven floor and the flame spreader under the oven floor, set the oven to bake and look for a good bright spark. If the spark is good the bake burner needs to be replaced,if it's a weak spark the electrode(spark Plug) will be needed.
The part numbers are
Bake burner 8054077
Electrode 8054129
They could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
applianceparspros.com
I hope this will help youto beable to repair your oven,
Gene
Aug 06, 2011 | Whirlpool Ovens
Maytag mgs5870adb range-gas runs, igniter does not click on any of the 4 burners. all the rest of the oven works
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Ovens
I have a Webber Q Family BBQ for about 2 - 3years. I noticed say last 6 months that the burners are not working properly and the grill is not hot enough ie take 3 times longer to cook a steak etc. I read...
OK, it sounds to me that when you changed the propane tank, you may have turned the gas tank valve on too fast. Doing so causes the built-in excess flow valve to check, which only allows a trickle of gas through. Do this: Turn off the gas tank, disconnect it and drain any remaining gas from the grill by opening a valve to a burner. Close the grill valve and then reconnect the tank. Very slowly open the tank valve and try lighting a burner again and see it that solves the problem. Douglas
Sep 12, 2010 | Ovens
I have a Thermador SGCS204R cooktop. The rear
Well first you need to verify that it is getting proper gas pressure to that burner. Try lighting the burner manually with a match. Does the burner look normal? If the burner flame is really small then you will need to remove the burner head and check the orfice for a restriction. If it looks normal then it probably is a weak spark from the igniter, igniter electrode is out of position, or burner head has dirty ports at electrode causing no ignition. Inspect the burner head. If it is removable then take it off and clean out the burner ports(eyes) with a sewing needle. If it is not easily removable then try doing this while it is still installed on the range. Also try using a wire brush on the electrode to clean any carbon/debris build-up casuing a weak spark. You can also try bending the electrode slightly with a flatblade screwdriver(be careful don't break the elctrode) away from the burner creating a larger spark.
Jan 16, 2010 | Ovens
I have a Maytag gas oven that I bought in 2001 and
It could be the safety cut out is broken? or not in the pilot flame. You could carefully check to see if the little probe is close to the burner and hasn't been knocked some how?
Otherwise you may have to call a gas cooker specialist . . Sorry.
Jul 29, 2009 | Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
75 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
