Question about RCA R52WM24 52" HDTV Projection Television
My rca r52wm24 Tv turns on but after about 20 minutes the screen goes black but I still have sound. Sometimes the picture will come back up and work fine after 10-30 minutes but it will go to black screen again. Then sometimes the picture will be fine for around 20 min utes agin flash to black then flash right back to normal. \r\nWhennthe screen does go to black it slowley fades out takes about 10 seconds to go black
  • 1 more comment
  • mcpheeters16 Mar 23, 2011
    I have tried componet on my XBOX and sat. still have the same problem.
    Tried switching to componet cables and still does teh same thing, tried via XBOX and satellite. Also tried going back to HDMI and still same results after about 20 min screen fades to black
    Over my head I will try calling a technician. thanks for the info
  • RCA Master
  • 2,098 Answers
Hi mcpheeters16,
First to isolate the loose connection from fault, check the cable connectors from the lamp and the ballast board. Pull-out the cables and then re-insert. Also check the ballast board from bad solder joints (crack/cold/dry joints). This is hard to spot I would advice you to work in the brightest area or use table/portable lamp to locate it. Once found, re-solder it.
You have to check also leaky/dried electrolytic capacitor in the ballast board and its power supply. This will do the same symptom. You must have a capacitor checker because not all of it bulged/dome at the top.
Another parts concerned is the lamp itself. Once near to its peak burning life it will produced an intermittent fault like what you've experienced right now.
If you don't have necessary tools and test instrument and can't do the job yourself, I would advice you to look for a qualified technician to troubleshoot the unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 23, 2011
  • 318 Answers
You may want to check your cables. If this is hdmi fed, a power surge could have affected the video input. Try changing inputs on your tv. If it persists, you can spend the money for another hdmi, do this if you only run surround sound through the hdmi otherwise, try switching the cable to color stream (compnents) Red, Blue, Green, with Red and White audio.
Rca r52wm24 the tv has double vision and shadows , then goes black screen. I unplug it for 10 - 20 min . screen still distorted
HELLO AM RICO, I WORK ON TVS SOMETIMES. ON THIS MODEL OF TV ITS COMMON FOR COLD SOLDER AROUND THE FLYBACK, CHECK THE FLYBACK, IF THERE IS COLD SOLDER AROUND THE FLYBACK. YOU NEED TO RESOLDER THE FLYBACK AND REPLACE A 5 AMP PICO FUSE. IF YOU NEED MORE HELP PLEASE FEEL FREE TO CALL ME AT 602-810-7149 I LIVE IN MESA AZ
Dec 31, 2010 | RCA R52WM24 52" HDTV Projection Television
The power cut on but no picture and the light blinks
my RCA tv R52wmWM turns on and after fifteen minutes the screen goes black
Oct 24, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA Model R52WH77 ..picture goes out after about 20 minutes, sound stays on.
Replace the deflection board. You can get a new ITC222A deflection board PSB-260 from www.tvrepairworld.com which also comes with instalation instructions.
Aug 01, 2010 | RCA R52WM24 52" HDTV Projection Television
My rca tv picture goes off after a few minutes but the sound stays on then the picture will pop back on then it goes through the same deal again
Resolder all pinns on FBT flyback transfomer and ck capacitors cp150 2200uf 16v if it is swollen or puffed up on top it is bad replace it and 2 more cp114 cp 120 220uf 35v.
Sep 18, 2009 | RCA R52WM24 52" HDTV Projection Television
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
My RCA 20F510TD 20 in. has sound but no picture
May need a horizontal driver transformer. Rca can not provide a part number. In the future don't buy this junk from China.
Jun 22, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
RCA R52WM24 52" HDTV Projection Television Logo
244 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
