Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
My device keeps telling me that I have entered the wrong password for my network, when I have put in the right password multiple times.
  • Linksys Master
  • 32,281 Answers
If your Linksys admin password was not changed and your router is unsecured then someone could have changed your router's settings and network password.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Mar 22, 2011
Wrong password network
1 - out of account
2 - Clean all device
3 - Scan Anti Virus
4 - promising device driver
5 - open a new browser site
Oct 14, 2013 | pof.com
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
I have forgot the password of privacy lock of my samsung sgh m200 plz tell the correct way
Your Samsung device requests PIN (Personal Identification Number) and PUK (Personal Unblocking Key) codes to protect your SIM card and device against unauthorized use. Note that all PIN and PUK codes are provided by your network operator. Samsung is not able to provide you PIN or PUK codes.
Please take note of the following:
When your insert your SIM card and boot up your device for the first time, you need to enter the PIN code. For security reasons it is recommended to change it to your own code, instructions on how to change the PIN code in your device is provided in the user guide or Nokia web site. If the PIN code is entered incorrectly multiple times, your device may request a PUK code to further validate the user's identity and to unlock and change the blocked PIN code.
The PIN2 code is a PIN code which acts as a second layer of protection for certain features of your phone. If the PIN2 code is entered incorrectly multiple times, your phone may request a PUK2 code.
If you have forgot or simply do not know the codes, you must contact your Network Operator for assistance. However, if you have already contacted but the code does not work, you should consider getting a new SIM card.
Apr 30, 2012 | Samsung Cell Phones
Hello, i have a hp Hp Ipaq 5455 and want to use a wi-fi connection at home and traveling.I can see the wireless networks and it says connected after i write the secret password that was given to me from...
I would say that either your password is not right either wrong or in the wrong "keyslot"or your hp isn't getting the proper numbers from the router. Since you can see them and connect we can be almost certain there is nothing wrong other than a setting.
Past that a incorrect password or on some wifis incorrect case of letters or wrong position would do exactly this. Basically every time your hp (or any other device) sends data to the wifi it will send the password info. It doesn't need to have the password to see or even connect but to get the data past what is basically a firewall it needs the key which is the password etc. Usually the case doesn't matter for most wifi routers but on some it does all the time and on others it does if they are setup that way. I've been caught by that more than once as case is unusual. To any electronic device Password and password are two totally different things. As well there are normally 4 key slots or positions that password is associated with. You can actually have 4 different pass codes as a result. And again even if the password is the same if it isn't in the right slot then the router will ignore it as it is incorrect. Basically you have to keep trying to enter it in while trying any variations. You can also yell and call it names. Doesn't help but can make you feel a bit better about this irritation ;-)
Last thing is that a lot of networks use what is called DHCP service or Dynamic Host Control Protocol. All that nonsense means is that when you get connected the router assigns the numbers to the device. That is how it is supposed to work. What happens on a few handhelds is that this does not want to work so what you have to do is manually enter in the numbers. You need a ip# (something like 192.168.2.10), a net mask (usually 255.255.255.0) a gateway number which is the ip of your router (will be something like 192.168.2.0) and then you need the DNS numbers for your ISP which will be sim in layout to the previous examples.Once you enter these in you will be able to connect to the lan and out to the internet. I still use my Palm Lifedrive and it has this issue on some routers. On the ones that I have manually entered them in the network runs faster so it is worth doing.
So you need to keep checking the password and slot (till it hurts) as well as considering putting in the numbers manually. If you need help with that you can reply here and either myself or someone else can assist with that.
Sep 24, 2011 | HP iPAQ H5455 Pocket PC
No the password.but wont let us into the bios,it just continues to windows
Hi kellydmurry,
If you have the right password then you should be able to get into the bios , it could happen that the password you are entering is a wrong one , therefore without displaying any warning to you the laptop is not going into the bios mode.
A good idea would be to check the caps key which you enter the password, try it one at time.
If you entered wrong password multiple times , it won't accept the real password for much time, so you need to wait at least for 15 minutes before retrying..
Hope this helps ...:)
Aug 01, 2011 | HP Mini 1010NR Notebook
Grandaughter put in password does not remember it and when trying to use phone PUK Bloocked shows up
the following codes are provided by the network operator:
-pin code
-puk code
both of these codes are provided when you purchase a sim card and are usually written on the sim holder or on the provided booklet.
if u have the puk code, then u can enter a wrong pin multiple time and then the sim card will ask you for the puk code which then u can use to unlock the sim.
if u lost both the sim and puk, then the only way is to contact the network operator to give you a new sim card.
Don't try to enter a PUK code without knowing the right one.
hope this helps
Mar 06, 2011 | Samsung Cell Phones
Trying to configure my DLINK WBR-1310 and it asks for account name and password and i entered them right and it keeps telling me not connected. i just need to put a password for the wifi
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browserand enter the D-Link's configuration URL. OR open the browser on your laptopand enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter)
You can now go and configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 26, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I'm trying to connect my iphone to a friends wireless router and it keeps telling me I'm entering the wrong passkey
I can't count how many times I've told people this...
You're typing the right password, but the network either isn't the right TYPE (A,B,G or N) or the Encryption type on the password isn't being set right on the iphone You need to know the password, AND whether or not it's WEP, or WPA Then set it up in your settings to use that specific encoding type, and then try entering the pass :)
Jan 08, 2011 | Computers & Internet
I have tried multiple times to enter the default password of admin on my mn 500 wireless router but it says that it is incorrect any other suggestions
there is a hole kind button, not sure where it is located in your router, just keep it pressed for a 5-10 sec it will reset your router to factory default then you it can be accessible with the default username and password........do reply back
Oct 14, 2009 | Microsoft Broadband Networking MN-500...
Wi fi not letting me join
The blah blah, is importand as it will tell us why it isn't connecting. if you include the following info it will make it easier to help you. The normal thing to do is just to start over,unless you have other wireless devices connected.Right click on the network icon on the desktop, click properties, and go to make a new connection, in the left side of t the window, the wizard will walk you through the entire process. Sometimes when people try connecting several times it can change settings. Are there wired mahines, or is there just your machine. If it's just you then the wizard should work fine, but if you are on a network, you may have to include the encryption key and encryption type, like wap or wpa1 wpa2 , you must use the same key and same encryption to get it right
Feb 17, 2009 | Zyxel P660HW-D1 Router
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
109 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
