Question about RTO Lifestyler 8.0 MPH Treadmill Walking Belt
I have a Lifestyler 8.0ES. It starts up OK, but after a few minutes it stops cold.
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
What could cause intermittent engine stalling?
A bad MAP or MAF sensor could cause this type problem .
Mar 16, 2017 | 2007 Volkswagen Transporter 1.9
Car loses power for short time after normal running and cooling down for ten minutes
sounds to be symptomatic of a CTS (coolant temperature sensor). there are two, one is for the interior temp gauge, the other is for the ECU/PCM while both are basicalty the same part, often even the same P/N, they both do extremely different things.
Feb 24, 2014 | Ford Ka Cars & Trucks
Toyota 4runner problems
check for an over heating situation with the motor as what you say indicates engine over heating.
Jan 23, 2014 | Cars & Trucks
Our Hitachi EC119Sa will not start if the temp is lower than 60. It also kicks out the restart button
Easy test to determine problem. Plug compressor directly into outlet without extension cord. Start compressor with no air in the tank. It it starts, fill to 50-60 psi and unplug from wall to stop. Wait few minutes and plug the compressor back in. It it starts, most likely problem is too heavy oil or the use of extension cord. If it does not start after few minutes wait, most likely not unloading due to leaking intank check valve or bad cold start valve (see reference # 47 on your parts list). The cold start valve should release air from discharge tube after few minutes. If the intank checkvalve is leaking, the cold start valve will not work and stall the compressor. If all test ok, then just replace oil with 10 - 15 - or 20 wt. Good luck
Dec 26, 2012 | Hitachi EC119SA Twin-Stack Air Compressor...
97 cavalier starts and runs ok from a cold start after a few minutes of warm up it starts to run rough and miss. If i try to drive it it will start out ok but won't shift automaticly but shifts fine m
Sounds like possibly more than on problem, crankshaft position sensor, or ignition module likely on starting prob which maybe affecting shifting due to hard code in ecm, or shift prob could be shift solenoid in valve body of transmission. Both parts readily available from local parts store
Nov 27, 2011 | 1997 Chevrolet Cavalier
How do I lubricate lifestyler treadmill? While it is running or not and wear to I put the lubricate. I was give a Lifestyler expanse 550 treadmill and have no book with it
Turn off the unit then lift belt and apply the lubricant on the middle of the running deck , then turn on unit start it at 1.0 mph start walking on it for about 5 minutes.
May 27, 2010 | Exercise & Fitness
E2, E3, E4 CODES ON A SEARS LIFESTYLER EXPOSURE 1500 MACHINE STARTS OK BUT SHUTS DOWN W/ E CODES AFTER A FEW MINUTES.
an E2 is a speed error code and the others all just tell me you have a friction problem-elevate the incline up all the way,without mtr working,push yourself off backwards-did you use muscles in arms/lower back? was it diffacult? thats friction,like rubbing hands together for long time. Result, no lube under walking belt- replace mtr,controller,walking belt- cost- a new treadmill
Jan 07, 2010 | Exercise & Fitness
When starting from cold car runs ok for few seconds then hunts/missfire can cuts out.re starts ok but will do the same again ubtill you get a bit of heat into engine then its ok!
i advice you to change the spark plugs,this is cause because at cold start the engine needs a rich mixture in order to maintain a smooth idle,before driving the car,when starting from cold ,what you have to do is to accelerate up to 2000 rpm for 3 minutes then you drive it,then it should be ok
Sep 02, 2009 | 1992 Volkswagen Fox
RTO Lifestyler 8.0 MPH Treadmill Walking Belt Logo
109 people viewed this question
Top RTO Exercise & Fitness Experts
Howard
Howard
Jax Planet
Jax Planet
Marvin
Marvin
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
