My mah5500bww fills with water when washer is off
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Your water inlet valve is faulty. However, without a serial number, I cannot give you accurate information on part number. You can go to Appliance Zone and they can help you with finding the correct valve.
Kelly
Posted on Mar 22, 2011
Mah5500bww manual
You might try opening the little door where you add soap. When the machine is plugged in, a solenoid on the water valve is activated. This solenoid may be faulty and you should see water running through the area where the soap, etc is added. If you do, you may need to replace the water valves on the machine.
Sep 29, 2013 | Maytag Neptune MAH5500B Front Load Washer
What the heck does nd stand for? Why does it sometimes say nf? Model MAH5500BWW
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump.
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to, nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Tub fills with water
replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
First Choice Appliance
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Will fill with water but not continue with rest of cycles
hey i like that washer i have one too.so no tumble after fill? just dead! that may be boards because door latch would come into play a minute later.your wiring diagram in the consoel will give you some clues.you would have to call maytag on any board warrenty.but i dont think its that long.God bless ,tom
Jan 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
   This can be a bad inlet water valve.  Does it stop filling when you unplug unit?  If it does,  your valve is probably ok.  If it doesn't,  replace inlet valve assembly.
   If water does stop,  you may have problem where the air dome has become dislodged.  You need to remove a inner drum vane and then turn this spot to the bottom.  There should be a black ruuber unit there.  This is the air dome.  It mist be seated.
Oct 21, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
