Question about Intec PlayStation 3 Turbo Shock III Wireless Controller
The right thumb tick not working right when i push it left it gose right and when i push it right it gose right
  • 3,018 Answers
2012 Kawasaki VN 1700 Voyager sounds like a valve tap coming from Engine. It will go away after riding and warming up. Is it a valave tap or something else?
Hi,the sound you are getting is normaly to do with the camshaft cleerance between the camshaft lob and the shim on the valve,if when the sound gose away when the engine is hot its the gap getting smaller due to exspantion,I would leave it unless you can hear the sound when engine is hot,if you cant live with it the whay it is the only way to sort it out is to get a works manual and do the valve cleerances,which means takeing the rocker cuver off and checking the gaps between each lobe and shim and replacing with the right shim to make the gap right,hope this was some help.
Apr 23, 2016 | 2012 kawasaki Vulcan 1700 Voyager ABS
Can I change it from a right hand throttle to a Left hand throttle?
Is it a twist throttle on the end of the handlebars or a thumb bar?
if it's a twist throttle on the end of a handlebar.....no, because the throttle will have to twist away from you if you put it on the left, so it's totally not practical. If it's a thumb bar, a general rewire of speed potentiometer behind the push bar for forward and reverse will change throttle over to the left push and reverse over to the right push.
Jan 13, 2016 | Health & Beauty
Flasher hazaed
Sounds like you somehow have constant power to the relay. Check for shorted out wires.
Mar 06, 2014 | 2004 Oldsmobile Alero
How do put staples in this stapler?
vaduvur.jpg1. Hold the black handle -- top part -- of the stapler with your right hand thumb and forefinger. 2. Hold the metal casing right beneath the black handle, with your left hand thumb and forefinger. 3. Use your left hand thumb and forefingers and a wedge to separate the top black part and the metal casing beneath it. 4. Bingo!
Note: Switching the two different operations on to the other hand is unlikely to work.
Mar 14, 2011 | Swingline 87845 Optima ® 40 Desk Stapler
How do u swing the bat?
Your left thumb stick controls the batters eye, if you push in on the left stick it will show a transparent circle which represents were the batter is looking. If you place it in the same place the ball comes in it will show the pitch location and you make better contact. You use the right thumb stick as follows,
contact swing (pull back, release) power swing (pull back push forward)
defensive swing (push forward) check swing (pull back immediately after your swing has started)
you can also change the controls to just use the buttons.
Feb 13, 2011 | 2K Games Major League Baseball 2K8 for...
Can't remove battery cover
Turn the phone to battery side and place you left thumb finger at the edge of the battery cover..
Place your right thumb at the start position of your battery cover.
Now gently push down the cover with your right thumb and it moves slightly..
Then pull upwards as shown..
Kindly rate me in fixya if i am helpful..
Dec 18, 2010 | Samsung SGH-a777 Cell Phone
It only ticks when i first start it. after it heats up the ticking gose away and the car runs great! i have added the stuff to my oil that is supost to stop the tick... dint work. any ideas??
Try 5w 30 synthetic oil and some marvel oil. Ticking is likely a lifter...as long as it dosen't get worse, it should be OK the way it is and using oil I said may after time get it to quiet down.(took time to get that way and takes time to get it better) If it does get worse, it will need replacement.
Aug 02, 2009 | 2004 Pontiac Grand Prix
Laptop cannot connect to internet outside company domain using wifi at home
typically at home you don't need any proxy settings configured within internet explorer. often in a work environment proxy settings can be applied.
if you think thar you have access to modify the settings do the following;
right click the IE7 (same for IE6) icon on your desktop select properties and select internet properties on the dropdown list.
left click the "Connections" tab
left click the LAN Settings button
deselect all of the ticks (most importantly the Proxy server part)
left click OK
left click OK
then open up IE normally and see if this has worked.
note of caution though; if as you suspect group policy is pushing the settings, next time you logon to the company LAN your changes may be lost and you will need to remove the ticks again.
also if you still get no joy try leaving the Automatically detect settings ticked with the proxy part unticked.
Nov 06, 2008 | Computers & Internet
No QB vison with chill stream game pad on new maddens HELP
you need a new controller this one does not work well with any madden game. I returned mine good luck
Jan 04, 2008 | Logitech ChillStream Game Pad
Intec PlayStation 3 Turbo Shock III Wireless Controller Logo
79 people viewed this question
Top Intec Video Game Consoles & Games Experts
Martin Murray
David
David
Colin Stickland
Colin Stickland
Are you an Intec Video Game Console and Game Expert? Answer questions, earn points and help others
