Question about Dryers
I have a Maytag Quiet Plus 2 dryer, I have a few problems with it.. #1 The timer does not work on Certain Cycles, and #2, It sounds Like a Mack Truck when it is Running. What gives?
  • 184 Answers
SOURCE: Maytag Dryer
CHECK FOR 240VOLTS AT THE OUTLET. A DRYER WILL RUN ON HALF THE 240 VOLT CIRCUIT BUT WON'T HEAT.
IF THE VOLTAGE IS THERE, CHECK FOR 240 VOLTS AT THE HEATER. IF IT IS THERE AT THE TERMINALS OF THE HEATER, AND THERE IS NO HEAT, THE HEATER IS BAD.
IF NO VOLTAGE IS PRESENT, TRACE BACKWARDS THROUGH THE HEAT CIRCUIT AND CHECK EACH COMPONENT IN THAT CIRCUIT. IF ONE OF THEM HAS 240 VOLTS PRESENT, THAT IS THE BAD COMPONENT.
POSSIBILITIES ARE, HIGH LIMIT THERMOSTAT, CYCLING THERMOSTAT, THERMAL FUSE, MOTOR CENTRIFUGAL SWITCH, HEAT SELECTOR SWITCH, TIMER. POWER CORD.
Posted on Apr 08, 2008
Illeagle
  • 525 Answers
SOURCE: dryer won't cycle
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0088_8_1.asp#Level1_18
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
    This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 25, 2008
  • 1214 Answers
SOURCE: Maytag Quiet Plus 2 dryer
I can't speak for which one is best, but I I can help you fix the no heat problem.
I am assuming it's electric heat. If it is, I bet the element has failed. If you know how to troubleshoot with a volt-ohm meter, I can walk you through the repair.
Let me know if you have the wiring diagram, or can find it on the appliance. Also let me know if you know how to read one.
Posted on Feb 01, 2009
Greg20
  • 149 Answers
SOURCE: What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
Posted on Jun 22, 2009
dblred
  • 68 Answers
SOURCE: my dryer works ...tumbles ...heat works...timer
if it is on sensor dry, check to see if the vent in your house or dryer is plugged. If it does this in time dry, there is probably a broken contact in the timer not allowing it to advance, and the timer would need replaced.
Posted on Oct 09, 2009
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
Maytag quiet series 200 dryer, runs.dries cloths,but timer does not move to time out through its cycles,like cool down and complete or finished.?
It sound like a bad timer motor.check with a local parts store for the replacement part and remove the screws from the top rear housing and you will see how to replace it
Feb 28, 2015 | Maytag Dryers
Maytag performa washer only spins on 1 of 3 cycles.
This machines timer is bad ,basically you have bad contacts in the timer ,that why it only works at certain parts of cycle
Nov 20, 2013 | Maytag Washing Machines
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
My maytag Dependable Care Quiet Plus 2 /gas dryier
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Jul 28, 2009 | Maytag Dryers
Jun 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Feb 01, 2009 | Dryers
Dryers Logo
Top Dryers Experts
