Question about Black & Decker TRO910W Toaster Oven with Convection Cooking
The heating elements on top do not come on to toast or bake the topside. The bottom elements heat up just fine. How do I troubleshoot? Is it worth fixing?
  • 67 Answers
The following phone number will connect you with service department of Black and Decker and maybe they can tell you if it is cost effective to repair or if you should just buy a new one.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Posted on Mar 29, 2011
I phoned Black & Decker Customer Service at 1-800-231-9786 and explained that the upper two heating elements no longer worked on my TRO910W toaster oven. Also, I did not think that the appliance had lasted as long as it should have, given the time I owned it, the care I took in its use, and my having used it only now and again for toasting (not for roasting and broiling where I used my regular, full-size oven).
The woman who dealt with my call was very pleasant, courteous, efficient and forthcoming. She offered a solution which both surprised and satisfied me beyond anything I had expected from the call. Apparently, ACP (Applica Consumer Products) in Bedford Heights, Ohio act on behalf of Black & Decker to provide customer service.
Before calling Customer Service, I had phoned the Black & Decker Service Center at 1-800-738-0245. The person who received my call said that the Center did not have any interior replacement parts for the TRO910W. This made it impractical for me to repair the appliance. Also, I understood that Black & Decker preferred appliance owners not to undertake home repairs (probably for safety reasons).
Posted on Sep 11, 2012
My Toaster oven top elements are not heating up on the toaster function
If the bake function still works you can keep it for that. But the heating/toasting elements are not meant to be replaced / repaired because the lawyers told them there is too much risk.
Another matter if still under warranty.
Dec 14, 2017 | Toaster Ovens
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
B&D TRO200 Toast-R-Oven bake function does not work
its not repairable at any price . you have a bad thermostat , its soooooo common with this oven . asprie who makes this oven in china, then inports it with black & deckers name on it . has not made any parts for it , not even a wire shelf or a knob .....when something happens to it , you toss it in the trash .....
Mar 07, 2009 | Black & Decker TRO201 1550 Watts Toaster...
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
I bought a kenmore toaster oven. There were no instructions.
This controls the heating elements in the oven Briol// Bake// and Toast
Dec 16, 2008 | Toaster Ovens
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Open Questions:
Black & Decker TRO910W Toaster Oven with Convection Cooking Logo
842 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
derbed
Level 1 Expert
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
