Question about Garden
My Briggs & Stratton 6.25 HP engine on my push mower spilled gas from the air filter when the front of the mower is lower then the back. I did just get it out of winter storage and put new gassed in it
  • 4,354 Answers
You should not have any raw fuel spilling, unless the unit is inverted. I suggest that you rebuild the carb, no need to have a fire or explosion.
Posted on Mar 22, 2011
  • denis Mar 28, 2011
    Hi DocPlayer,
    As mentioned before the carb needs to be removed and cleaned. I think the float is the major problem. Check the needle to make sure it is not sticking and the float itself because it is probably leaking. Shake the float to check if gas has leaked in. Or another way is to wipe the float dry and look to see if you find any places that might be wet. If that is the case and I do think it is, replace the float. I hope this helps you out a bit. Best regards and good luck.
Need to know where the fuel filter is located
FAQ: Fuel Filter Replacement ' Briggs & Stratton Engines
www.briggsandstratton.com/us/.../fuel-filter-replaceme...
Briggs & StrattonWith this Briggs & Stratton FAQ, you'll learn how a fuel filter works in small engines ...properly strain the gas before it reaches the carburetor in your lawn mower, snow ...and uneven operation; Clean filters conserve the amount of gas you need ... The fuel filter will be located either inside the fuel tank or fitted into the fuel line ...
Servicing the fuel filter - Briggs & Stratton
www.briggsandstratton.com > www > Support > FAQs
Briggs & StrattonIf you still need help, you can submit your question by clicking the Ask a Question tab.... Some filters are located inside the tank, others are fitted into the fuel line between the tank ... The size of the holes in the filter will determine the largest particles that can get through the filter, and the number of ... Lawn Mower Engines ...
Lawn Mower Engine Fuel Filter Installation - Briggs ...
Jan 01, 2016 | Garden
I have A briggs & stratton 300 engine. When I start the motor surges at idle and full throttle.
Leaking head gasket or intake gasket
Try a new spark plug & fresh fuel first,
& clean the air filter
Sep 26, 2014 | ROPER OUTDOOR POWER PRODUCTS Weedeater 20"...
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
Remove the air cleaner cover and the air filter then spray into the filter box.
Jul 14, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Black small hose is loose on briggs&stratton 550ex mower engine
fuel should never be coming out of the air filter. do you mean the pipe that goes from the engine to the air filter housing? if so thats the crankcase breather pipe and you shouldnt be getting fuel there either. if you have fuel coming out of the air filter housing then you carb is probably flooding and will need stripping and the needle vale and foat looking at
Jun 21, 2014 | Briggs & Stratton Lawn Mower Air Filter...
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Gas Push Mower - Briggs & Stratton, will start but run for
The jet in the bottom of the carburetor is clogged up. The engine will prime but after that fuel is burned off, the engine stops. The jet is not allowing fuel to be sucked into the engine.
Sep 29, 2009 | Garden
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
20 hp briggs and stratton revs up and down
lower throttle and if that doesnt solve it check the governor might be broke
Jun 24, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
