Question about Briggs & Stratton Garden
I have a yard machine 6.25 HP 22 - Briggs & Stratton Garden
5 Suggested Answers
  • 32 Answers
SOURCE: where do you drain the oil on a 4 hp yard machine
to drain the oil then you open the oil cap and tip it over and let the oil drain out.
Posted on Jun 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: mtd 22" yard machine staryts and dies using prospray.
Remove the float bowl again and remove the BRASS Jet in the bottom of the venturi throat. Clean the pin hole of the Jet so that you can see through it. DO NOT force anything through it. Just clean it. Underneath the jet is the venturi tube itself. It is also unscrewed with a screw driver. Remove it and clean all ofthe holes in it. Then reassemble tube and jet in to the venturi. Check the BOWL NUT for 2 holes. If the holes are clogged your engine will suffer from a lack of fuel. Lastly check that you have FUEL flow from the tank to the carb. If the tank outlet hole is clogged you will also have a lack of fuel problem.
Posted on Apr 11, 2010
Testimonial: "Thank you for your very helpful advice and detailed insructions as to what to do to correct this problem with starting my mower. runs like new now. Thanks again for taking the time to help me out. Grump."
mikehowy
  • 177 Answers
SOURCE: Yard Machines 22'' mower, pull cord won't extend
is it flooding or is it second hand , some people cut the cord and dont fit it back properly , if it is flooding you will get hydraulic lock , answer to your question is carby service and over haul
Posted on Jun 07, 2010
woobie dog
  • 1273 Answers
SOURCE: Yard Machines 22" push mower
Hello, W/D here.
2 suggestions: 1. Check the fuel cap for pluggage, paying particular attention to the pinhole vent in the cap, and 2. Clean the air filter. A plugged (or nearly plugged) filter can also cause these symptoms.
Best regards, --W/D--
Posted on Feb 14, 2011
Mower machine, 6.5 hp , model 20016 , 22" high-wheel,. so question is :gasoline pass from carburetor through air filter,what i do?
Its quite common to see fuel in or around the air cleaner to carb casting. Side mounted carbs on Tecumseh and Briggs tend to spray a little back. If its running back then get someone to strip and clean the carb, its got some debris in it.
Sep 29, 2016 | Mtd 22" Yard Machine Push Mower
How do I change the fuel filter on a yard Machine 6 Hp mower
A lot of the smaller machines do not have fuel filters, unless you put one in line yourself. Some will have a small screen in side to fuel tank or if you separate the tank from carb you might find a filter, most likely your machine is not equipped with a filter. Good Luck...
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
Have a 22 inch yard machine snow blower the belt that turns the blades broke what size belt does it take
MTD has made many 22" machines over the years. Please repost your question indicating the model #
Dec 27, 2010 | Mtd 22" Yard Machine Push Mower
I have a Yard Machine Gold 22 h.p. 8 speed with a 46" deck. Where can I find an online manual that will show me how to remove the deck step by step?
lower deck remove belt from engine disconnect any hangars connecting deck to tractor raise deck lever pull out deck reverse prosess to install
Aug 01, 2010 | Yard Machines MTD Gold 23 HP Garden...
Can't get it to go when I pull the rope
A new plug might help also check HT lead
Jul 26, 2010 | Mtd 22" Yard Machine Push Mower
Where do you drain the oil on a 4 hp yard machine
Jun 12, 2009 | Mtd 22" Yard Machine Push Mower
Where is the solenoid on yard machine 12.5 hp riding mower?
hello....usually the solonid is behind the housing surrounding the steering wheel, if it's a front engine riding mower. Just follow the large red cable from your starter, this is connected to your solenoid....hope this helps...
Jun 07, 2009 | Mtd 22" Yard Machine Push Mower
Replace pull rope
Yes, take the shroud off that the recoil is riveted to
Apr 15, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
233 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
