Question about Canon PowerShot A560 Digital Camera
Even with absolutely fresh batteries properly installed, I keep getting a "change the batteries" message, and then the camera shuts down. It worked fine for two years!
  • 32 Answers
Peter,
Try using a Q-tip and some alcohol to clean the contacts inside the battery housing of the camera - it's possible there's enough build up to prevent a clean connection.
Thank you.
Posted on Mar 23, 2011
  • maebnus46
    maebnus46 Apr 18, 2014
    a good place to start.
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
Even with fresh batteries installed, I only get a few shots before the "battery empty" icon appears. Then, if I remove and then re-insert the same batteries, the initial result is a green...
Hi, well this is a pretty common problem, with this and many other cameras of a similar sort, what happens is that inside there is a power conditioner circuit, components, usually a "pass" transistor in this circuit partially fault, and increase the current draw from the battery dramatically, and this causes it to go "Flat" very quickly.
There is little that can be done DIY, what has to be done is to take the camera to an Olympus service center, and ask for a "Quote" for the repair.Then you can make an informed decision as to what to do, repair or replace.
Feb 09, 2011 | Olympus SP-560 UZ Digital Camera
I have a Pentax M20 camera. I love the camera but all of a sudden I find that when I turn the camera on, the camera almost instantly shuts off. I have new batteries in the camera. When the camera first...
I am sorry you having that problem, and even more sorry I do not have a solution...On my Pentax Optio M10 batteries rechargeable or fresh alkaline only seem to last about 5-6 pictures before the camera deems them flat without charge and shuts off...it is so annoying I assume yours is possibly doing the same.
I suspect this to be a camera problem, I also notice the camera dos not recognize all rechargeable batteries some of them do not even get acknowledge.
If anyone gets a solution help us both....
Oct 14, 2010 | Pentax Optio M10 Digital Camera
Keep getting change battery message and camera turns off.
I had this on mine. If you pen the battery compartment door, you will see a piece of plastic labelled "CR1220". You can pull this out and replace the little CR1220 battery that it holds. That ought to solve your problem.
Jun 16, 2010 | Canon PowerShot A720 IS Digital Camera
Nikon L12 Battery Fault
I don't know if I have the very same problem with my old nikon Coolpix E44600. I may go through the pictures I have already taken but when I try to take a new one, just as I shoot I get the message the "battery exausted" message and the camera shut down.
Jan 27, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon coolpix 2100 camera won't stay on
I've been having problems with the batteries and the camera refusing to start even with fresh batteries. I bought loads of new rechargable batteries and have finally found some that work. Duracell rechargables. Theyr'e brilliant and keep their charge for ages despite continuous use of the camera! Last summer I managed to take 975 photos before the batteries finally decided to give up!
Jan 27, 2008 | Nikon Coolpix 2100 Digital Camera
Canon PowerShot A560 Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
