Question about HP Office Equipment & Supplies
Printer needs reconfigured - HP Office Equipment & Supplies
My son went to youtube and found a video on how to change WPA to WEP. Now my network is not working on my printer and laptop
you need to reconfigure your printer and laptop to WEP but I don't recommend it as WEP is terrible and easy to crack.
connect to your router via cat 5
open internet explorer and browse to http://192.168.1.1
login with the default login is blank. pass is admin.
go to wireless and to wireless security.
change it back to WPA personal.
change the passphase for the wireless password.
use the new passphase you created and tell your printer/laptop to join your wireless network
you may want to change your wireless password too so your son won't reconfigure your router again.
do this by going to administration and change the password there.
Apr 03, 2011 | Linksys Wireless-G WRT54G Router
Can't print wireless from my new canon mx860 printer. Prints fine wired.
I believe you need to reconfigure the wireless settings on the printer. You need to get the same exact wireless settings on your router.
Oct 03, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Reconfigure epson stylus nx300 ink cartridges for refilling? Tks
The only way you can do that is by using a chip re-setter. They have them in refill shops, and I think you can buy one on e-bay.
Jan 20, 2010 | Epson Stylus NX300 All-In-One InkJet...
Hi i have a lexmark all in one printer,recently i changed my router and now cant connect the printer wirelessly to the computer!
You will have to reconfigure the printer with the router and then reconfigure the PC. All routers don't have the IP address range. That might be the reason why it isnt working after changing the router. Also, if you were using the printer wirelessly, the SSID (network name) and the wireless security needs to be reconfigured to match your new router. The simplest way to achieve this would be to connect the printer hard wired to the router; uninstall the printer drivers completely from the PC; and run the setup disk again. The setup will walk you through the whole process.
Please get in touch if you need further clarifications.
regards
Sandeep
Oct 27, 2009 | Office Equipment & Supplies
How do I reset the regionalisation? I have UK 7210 with US cartridegs whch it won't recognise.Someone, somewhere must have noted the HP tech instructions for this process? Can't be rocket science; can it?
hi to reconfigure the regional setting we need to do a reset on the printer which will reset the printer to its factory settings to start the reset ensure that the printer is powered on and disconnected from the computer now press the # and the no 6 button on the printer together and then remove the power cord from the back of printer while pressing the # and 6 after 10 sec reinsert the power cord and relese the buttons it will start a semiful nvm reset after 2 min it will ask you the language and then region select the region and your printer will be reconfigured all the best
Jul 19, 2009 | HP Officejet 7210 All-In-One InkJet...
8860 Reconfigures itself
Gotta be a setting on the machine. Set this to say A4 and make sure the same is set in your print dialogue box
Apr 24, 2009 | Xerox Phaser 8860MFP/D - Multifunction -...
Can't use my original ink # 363
Actually you cannot use your # 363 ink on your photosmart c6180. The ink is not compatible with the printer. Photosmart c6180 only uses HP02 vivera inks. And there is no way that you can reconfigure it because it is factory default. Unless you bought an HP02 ink from other country outside US and bought the printer in US, that's the only time that we can reconfigure the regionalization of the printer
Aug 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Reconfigure ink to print setup?
Actually, epson printers needs all the inks for it to print. The print heads on epson are fixed thath is the reason why they need to be primed with inks when printing to prevent print head damage.
Feb 12, 2008 | Epson Stylus Photo R340 InkJet Printer
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
