Question about Air Hogs Spinmaster Air Hogs Havoc Stingers
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
    New Friend:
I got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Posted on Jan 03, 2013
  • William Landrum Jan 03, 2013
    P.s. DOES ANYONE KNOW WHT THE LITTLE BLACK BUTTON ON THE BOTTOM OF MY HAVOC HELI DOES? Its right in frno of the power slider switch!!
  • 156 Answers
SOURCE: Power
The battery seems to be bad. I get my Peg Perego Batteries at http://www.shopjandl.com/
My batteries last about 3 to 5 years, as long as my kids are charging them up each time they go down.
Hope this helps
Posted on Jul 10, 2009
  • 25 Answers
SOURCE: Helicopter keeps spinning in circles and won't lift
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
Posted on May 17, 2009
SOURCE: silver bullet helicopter wont stop spinning counterclockwise
i would continue to hold the trim. this happended to mine and i held the trim for a couple of seconds and it leveled out. also i have a problem, mine wont generate enough lift to take off. do you have a solution for that?
Posted on Feb 17, 2010
SOURCE: My new u-control helicopter is experencing spinning
how much is it spinning after and if not to much adjust the st. trim on the controller.
Posted on Mar 05, 2010
SOURCE: How do I get my
Turn the trimming the opposit way that the your heli is spinning until it stops
Posted on Nov 25, 2010
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 | Toys
Spinning
It's not fully charged. Try putting in brand new batteries and fully charge before trying again
Jan 05, 2014 | Brookstone Remote Control Helicopter -...
Will not fly lift . Seem to run well but will not lift off the ground
The batteries on the Helicopter need to be fully charged to take off.
And important: to recharge the helicopter fully it needs really good base unit batteries.
I find all this a waste so - I used a wall power supply to supply suitable power to the charging bases of these helicopters give more consistant results than using batteries.. Just make sure you are using a 9V DC wall transformer (6 1.5v batteries = 9v) and that the polarity is correct.
manual is here
http://www.brookstone.com/webassets/pdf/651307p_manual.pdf
Dec 18, 2013 | Brookstone uControl Cloud Force RC...
My sons S107 lower rotors would not turn. I disassembled and solved a gearing problem. At this time a wire came loose that supplies power to the tiny little prop at the tail. I fixed this problem too. ...
Check if s107 is fully charged.
Both rotors (lower and upper blade) should be working at full capacity. If either one of them is going slower, S107 won't lift up from the ground.
Check that gears are not too tight on each other. They should be able to rotate (leave cca 1mm space up/down between them)
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
My hawk talon v3 is doing everything fine except it wont come off of the ground the blades are spinning they are taking some wait off the ground but in all the helicopter stays down what can i do?
try taking the body off of the skeleton and cleaning the rotor cylinder, might be dirty or have some carpet/hair fibers keeping the blades from running at full speed even if the battery is fully charged
Jan 08, 2011 | Team International Hawk Talon V3 RC Indoor...
Hawk talon v3 wont get enough power to lift off the ground after being fully charged. another hawk talon v3 rear tail rutter wont spin to go forward. how do I fix these problems in these two...
I too had the lift-off prolem and I fixed it by gently pushed the upper gear all the way up, using a nail through the bottom of the copter and a hole in the lower gear, while pushing the lower rotor down.
Dec 29, 2010 | Team International Hawk Talon V3 RC Indoor...
Yiboo UJ4708 will not lift even after being fully charged. It will just hover an inch off the ground. It doesn't sound right to me either when its running.
i had the same problem.. one of the gears isn't fully engaged.. if you look at the internal mechanism, you'll see two small gears on opposite sides, each engages a larger gear... during impact, these gears can slide and become not fully engaged. That is the strange sound you are hearing. this also prevents the propellers from spinning up fast enough to get fully off the ground. I used a small jewelers screwdriver to reach in and push the problem gear back into place.
Sep 28, 2010 | RC Remote Control Helicopter Ready To Fly
Apache havoc micro... can not trim the helicopter it spins counterclockwise.
the cause of this issue is hair or something preventing the tail rotor to spin properly.. i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
Mar 02, 2010 | Air Hogs Havoc Heli Helicopters
Silver bullet helicopter wont stop spinning counterclockwise
Feb 13, 2010 | Shuttle 9094 Emax Remote Control...
Air Hogs Spinmaster Air Hogs Havoc Stingers Logo
633 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
