Question about Dishwashers
I can no longer latch my dishwasher i can get it open but not closed now to wash with. should I buy a new latch which is easy to install and take out or can i macguiver it?
  • 822 Answers
The latch can get stuck in the closed position when door is open,...... to fix it....undo the screws on door.............seperate front from back.....the latch can then be "opened "...........put door back together n job done............
cheers
Posted on Mar 22, 2011
My soap dispenser will not open during the wash cycle
There is a quick test to verify there is a problem, this test will take about 2 mins. Open the door, close the dispenser (latched), on the control panel itself, push in this order hi temp wash (HTW) than sani *3 times in that order*. So that means HTW-Sani, HTW-Sani, HTW-Sani. What this will do is run a control service mode, all the LED's will light up, close the door and wait until it stops, within about 45 seconds you should hear the dispenser open. If it opens it is functioning normally, if not, it should be replaced.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 29, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
I have a D3251 and the door won't close/latch....how do I solve this problem? Thank you
I just had this problem and it seemed to be fairly easy to fix. Some times when you open and close the door interrupting washing cycles, the latch will think it is already latched. Even though it will still close with pressure, it seems like it will pop back out on you. Here's the fix. If you open the door, you will see a white plastic accepting latch that can be flipped back into the fully open direction using a screwdriver. That seemed to do the trick.
Jun 02, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
Latch is not working properly
It's possible the machine is slightly twisted.
Try re-levelling it to start.
You can usually tell when the door is not quite closed if it looks out-of-centre.
The next thing to check is lubrication of the catch. Try some WD-40 in the latch mechanism.
If still no better, then the latch may need adjusting by removing the front panel (unplug machine before doing this).
Grease the moving parts and adjust catch for easy closing.
May 02, 2010 | Dishwashers
My matsui dishwasher, seems to have broken and will not open. Is there anyway to get door open
Hi,The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Also the latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
Apr 14, 2010 | Dishwashers
When i close the door i hear it close but i have to put something up against it to keep it washing if i take it away it stop washing
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Nov 19, 2009 | Maytag Dishwashers
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Kitchenaide dishwasher latch will not stay closed. It pops open during washing cycle and the machine stops and does not complete the cycle
The dishwasher was not properly leveled on installation. I used a carpenter's level
and trued up the problem. The door now stays closed.
However, the latch design is faulty in that it does not ever feel securely latched and that is true of all the Kitchenaides that I tried in the showrooms.
Jul 19, 2008 | KitchenAid Dishwashers
Danby dishwasher
Call Marcone Supplies, Tampa Florida. (they are Danbys Supplier for parts.) DO NOT WASTE YOUR TYIME CALLING DANBY. They are not helpful. Danby 18" Dishwasher. Model # DDW 180 2W Parts 800-482-6022. Marcone:Very helpful. My door is open; thank goodness; it just will not stay closed. Latch broken on door. I have to order the "whole handle assembly" (all one piece which includes the door handle latch too.) $4.16 shipping from PA. I am in Calif. Total $12.53. 2 screws. Easy. I can do it, I know I can. (Signed, a woman in LA!)
Jan 22, 2008 | Danby 17 in. DDW1802W Designer Series...
Dishwashers Logo
162 people viewed this question
Top Dishwashers Experts
