Question about Garden
I can't get my egg hot enough...or past 400 degrees, for that matter.
  • Nicholas Lemarr
    Nicholas Lemarr Mar 22, 2011
    Please be more specific. We need more information.
4 Suggested Answers
  • 81 Answers
SOURCE: flame not hot enough
Replace the t-stat.
Posted on Jul 25, 2009
gcken
  • 140 Answers
SOURCE: i cannot get the extra large big green egg hot
Yes use ONLY Big Green Egg Charcoal If you use anything else you can damage it
Posted on Aug 19, 2010
  • 19 Answers
SOURCE: top rings not hot enough to even boil an egg
Buy a new cooker
Posted on Feb 03, 2015
I'm trying to make egg rolls but I'm not sure what to put in them? Please help
Ingredients
  • 1 pound ground pork
  • 1 teaspoon ground ginger
  • 1 teaspoon garlic powder
  • 1 quart peanut oil for frying
  • 2 tablespoons all-purpose flour
  • 2 tablespoons water
  • 2 cups shredded cabbage
  • 2 ounces shredded carrots
  • 8 (7 inch square) egg roll wrappers
  • 2 tablespoons sesame seeds (optional)
Adjust Servings recipe yields 8 servings Directions
  1. Season pork with ginger and garlic powder and mix thoroughly. Heat mixture in a medium skillet, stirring, until pork is cooked through and no longer pink. Set aside.
  2. In another large skillet heat oil to about 375 degrees F (190 degrees C) or medium high heat. While oil is heating, combine flour and water in a bowl until they form a paste. In a separate bowl combine the cabbage, carrots and reserved pork mixture. Mix all together.
  3. Lay out one egg roll skin with a corner pointed toward you. Place about a 1/4 to 1/3 cup of the cabbage, carrot and pork mixture on egg roll paper and fold corner up over the mixture. Fold left and right corners toward the center and continue to roll. Brush a bit of the flour paste on the final corner to help seal the egg roll.
    1. Place egg rolls into heated oil and fry, turning occasionally, until golden brown. Remove from oil and drain on paper towels or rack. Put on serving plate and top with sesame seeds if desired.
Apr 20, 2014 | Cars & Trucks
Amana Furnace
The furnace may have a cracked heat exchanger.
Dec 19, 2013 | Heating & Cooling
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Nov 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
