Question about E-Machines emachines (emachinees) CD-ROM Drive
The door in my tower wont open to record discs
  • 519 Answers
This often happens & one way of opening the door is to insert a paper clip in the tiny hole which is situated on the door panel of the drive. The drive may just need cleaning or it could be that there are worn parts which prevent the door from opening as it should.
Best wishes,
Graeme.
Posted on Mar 22, 2011
    Sergeant:
  • 296 Answers
Use a flat tip screwdriver.
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
Samsung DVR-R130 wont release the disc.
Most players will have a small hole on the front panel where you can access the manual release using a paperclip. I checked your Owner's Manual, and didn't see any mention of it, but most every DVD player I've ever seen has one. Hope this helps.
Dec 24, 2007 | Samsung DVD-R130 DVD Recorder
My recorder wont record on new discs
Daewoo DVD Recorder/VCR combi (I believe the model number is DF-4100P it wont record on disc but it will on tape mode plus the drawer in the dvd wont open please can someone send me an answer of whats wrong with it thank you
Apr 05, 2010 | Daewoo DVRS05 DVD Recorder/VCR
Disc Tray will not open
My Gateway model #AR-230 tray would not open after several years of use. Removed the black sheet metal cover from the player to access the tray mounting screws in the black plastic tray frame. By tightening or loosening the little screws on both sides of the front of the tray mechanism, I got the tray to slide out (open) reliably again. The problem is the very close tolerance of the internal tray mechanism with the front case opening causes a mechanical hangup or interference. chemicalladdie
Sep 14, 2009 | Gateway AR-230 DVD Recorder
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
Stopped recording/won't open door for disc at all
There's a slot on the bottom where you can insert a small slotted screwdriver and slide it to the left to get it open.
Apr 03, 2009 | iLO DVD Recorder DVDR05
Tower disc drive won't open
What bunnydawg means is it connected properly to the psu. If lights flash it could simply be jammed If they dont open up the back and check the plug with four metal points in it is in properly
Sep 07, 2008 | Acer Aspire™ T180 PC Desktop
No disc kicks disc out
I have the problem of it refusing the disc if the door opens before I have filled the whole disc and finalized it. As long as I don't open the door till the disc is full and finalized, it works.
Aug 30, 2008 | Samsung DVD-R130 DVD Recorder
Computers & Internet Logo
104 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
