Question about HP Computers & Internet
The pc starts but not sure if it boots all up as now no monitors will work on it tried everything it went funny when i took the hardrive out i did replace the hardrive but still not working i tried all monitors aswell
    Novelist:
    Scholar:
  • 125 Answers
The graphics card might be in properly, or you need to replace card. Try and see what happens. If you have on-board screen adapter try using that and unplug the AGP or PCI one first and see if screen appears. Also if your using a Digital monitor check if the monitor is in Digital or Analog mode, dependnig on how you plugged in.
If all else fails, try taking out the battery on mother board and restarting computer.
Posted on Aug 03, 2008
When I booted up my PC 4 days ago, my Symcmaster 193P monitor started immediately blinking continuously and very fast; it did so on the POST screen and went on after booting in Windows too. It stopped and...
Yes i do agree with you there is no problem with a graphic card,and i suspected it to be a problem with the cable which is used for connecting but it was fine when you swapped the monitors however i would still suspect on the slot where the cable is connected,may be you should try samsung service center before you decide.
Post back for more solutions we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | Samsung SyncMaster 193P 19" LCD Monitor
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
I have a ABIT-V17 Motherboard with intel pentium 4 CPU and 1GB\RAM.. and Windows 7 Ultimate OS... I was doing a system cleaning when I removed the power cord and turned off the power I started taking my...
U indicated that you were able to get into the bios. Strange that all you did was dis assembly the PC, put it back together the same way, and now it does not work. Assuming you put everything back the exact same way it should work. Make sure that all of your connections are good and tight. Also check to see if the PS is working or connected properly. Try disconnecting all components except the memory and monitor and boot. If it works to a screen turn it off and start hooking up other peripherals one by one till you get no video or it stops working.
A bad peripheral can often disrupt a normal boot up process and cause all sorts of mayhem.. Check them all out.
And make SURE that your memory chips are in there properly!!!!!!!!!!!!!!!!!!!!
Mar 03, 2017 | Abit VI7 Motherboard
Monitor doesnt reckinize that the hardrives on
try taking the ram chip out then see if thats the prob by turning on the computer without it if its not, try unhooking the cd drive and then try turning on the computer if thats not it then try unhooking the hard drive and check if thats it one of those should be the problem i had the same prob but i messed with the ram chips and it worked i just took it out started it up and it worked if thats the prob just start it up then shut it down and put the ram chip back in and it should be fine
Jun 10, 2009 | Northgate (STAX2517C2) PC Desktop
Pc monitor blank
Perform a system restore to see if it will restore your settings.
May 12, 2009 | EliteGroup GF8200 MCP78S AM2+ Atx 32GB...
EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Feb 04, 2009 | eMachines T6534 PC Desktop
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
Acer Laptop
The connector may be broken.
all I can suggest is to take it in to be checked.
I suppose you did insert the hard drives in the right way.. If I remember right its the text side up (towards the keyboard)
Jun 26, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
