Question about Ovens
My oven wont come on. press any button and it reads "off".
If yours has a digital keypad, there may be a lock button or code.
Posted on Mar 22, 2011
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
When the "bake" button is
hello,the control is locked. i belive if you hold the time button for 5 seconds it will unlock. hope this helps please rate me thank you...
Jun 07, 2011 | Ovens
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
How do i turn on a white atlas ceramic electronic oven, the ceramic top is working,but the oven screen flashes from"0:00" to "auto" when i try and fiddle round with the oven...
Turn the oven control on. Now play with the buttons on the electronic timer/clock. Try all different combinations. Trying pressing them at the same time. This may take 5 minutes or more. If the timer is not faulty this will work, be patient. When the oven indicator light comes on the oven is on and the timer is now in manual mode.
Feb 25, 2011 | Ovens
I'm pressing all the buttons on the oven but none of them are working except when I press "Start" and "Clear/Off". When I press these two buttons, I hear a beep but nothing happens....
Sounds as though you control board is shot. Part number WB27T10312
It is expensive but its with a high since of probablity.
Of course before you do this ...something simple could be tried. This would be to kill power to it and let it site for 30 minutes and then turn it back on (Breaker would do this).
Replaceing the board is not that easy since it has lots and lots of wires. If doing so besure there is no power and draw a schamtic of where the wires are before disconnecting them
Thanks,
Shawn
Jan 31, 2011 | GE Profile JTP18 Electric Single Oven
Ican't turn the oven on. When I press "Bake" it goes to LOC and then turns itself off. I should be able to adust the temperature (+ or -), then press start.
Hi
If it is a GE oven then you can try and reset the LOC error by pressing 9 and the 0 simultaneously for 5 seconds or until the LOC disappears. Alternatively you can try pressing the "Oven Lockout" or "Range Lockout" button on the control panel and then the "Start" button. Hope this helps... Please post back with make and model# of your Oven if you need more information.
Daniel
Nov 10, 2010 | Ovens
DACOR IS A PEICE ****
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
Jul 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
