Question about Sony Computers & Internet
Have a brand new Sony Vaio. There has always been a green indicator icon in the lower rt task bar( don't remember what it meant) is no longer there.How do I restore that?? Also along the lower front edge of the lap top there are three tiny lights. 1st on is green indicator light for the wireless It's ok. 2nd on is not lit up and the 3rd one (orange) now blinks. Is this as it should be??
    Sergeant:
  • 296 Answers
1. Rick click on the notification bar. Enable the "green indicator".
2. It's dependent on what you are doing.
Posted on Mar 22, 2011
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
No matter if secure or not will not connecet to wifi
Hope this helps
Nov 19, 2012 | Sony VAIO VGN-N325E Notebook
Added RAM memory and did windows disk check on my Sony Vaio desktop with Windows xp, now IE and other programs will not open. Nothing happens when icons are clicked and bottom toolbar does not load i
First, remove the memory and replace the old memory, does the help? Be sure to unplug and REMOVE battery. Second, do a system restore to before this problem. Is the memory the exact type that was removed? Open the Task Manager and look for a process "explorer.exe" select and click on "end process", in the task manager open file, New Task (run..) in Create new Task type: explorer, click on OK.
Nov 16, 2012 | Sony VAIO Notebook
Will not connect to wifi network
Hope this helps
Nov 11, 2012 | Sony VAIO VGN-N325E Notebook
My sony vaio doesn't recognize the battery and thinks that the battery is not present or bad. I replaced with a new battery and still have the problem. Over the past year, the battery life indicator has...
May need to remove the CMOS battery for 1 hour.
This is technical task that involves stripping laptop completely.
Is the new battery same brand or "pirated" as the vendors one should be recognised
Mar 29, 2010 | Sony VAIO VGN-FS550 Notebook
How do i adjust the sound on sony vaio vgn fw53gf?
click on the sound icon on the right side of the task bar.. you will then be able to adjust the audio.. hope this helps ü
Mar 29, 2010 | Sony Computers & Internet
No internet connection
if you are worried about the icons that are sown in the tray system ( lower right in the task bar ) those are showing the other connections that are not working at the time ...for example the LAN cable conection ...and the blue tooth ..those will appear not connected if you have no cable on the Lan card or blue tooth device connection ...even if you are connected via wireless those will appear unless you choose to unchecked the show in tray ...
if you are asking about the connection you have made wireless and it doesnt work ...you probably have a driver problem ..just reinstall the driver for the wireless card if you know that the connection should work ...if you have acces on the net wireless those icons that are x-ed on the right on the task bar are for the other connection methods ..so do not worry ..
Jan 06, 2010 | Sony VAIO VGN-CR320ER Notebook
Missing battery indicator in the task bar
No this is more typical with Windows Vista users as updates can disable the icons from the notification bar.
Chose 'taskbar' tab, then click 'customize' and chose the option for the battery icon and change to 'show' .
If you need anymore help please post back.
Regards.
Nov 26, 2009 | Microsoft Windows XP Home Edition
After signing on nothing just the background photo
Have you tried selecting "Use last known good configuration"? If not, try it be that will fix your problem.
Please remember to rate me.
Thanks
Let me know how it turns out.
Feb 02, 2009 | Sony VAIO PCG-K35 Notebook
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
