Question about Plumbing
Where do I find oil resvoir replacement - Plumbing
    Sergeant:
  • 296 Answers
EBay.
Posted on Mar 22, 2011
09 aveo oil @ white foam in coolant resvoir
flush your radiator first . if it appears again you need to do a pressure test .. there is a pressure tester you can screw on where your cap goes and see if there is pressure loss after pumping up the gauge. if there is possably a head gasket or leak internal somewhere
Apr 06, 2014 | 2009 Chevrolet Aveo 1.6
White foam in coolant resvoir
oil in water will send the water white. . Grey is engine oil and pink is transmission oil from a cracked transmission oil cooler in the radiator
Apr 06, 2014 | 2007 Chevrolet Aveo Sedan
Oil in coolant resvoir
Not good! The coolant and lubricant in the engine should never come in contact with each other.
Check the oil dipstick - if it is white / foamy white - is indication of coolant entering the crankcase and mixing with the oil. This can happen if the engine block has cracked or head gasket is torn / damaged.
After the engine has been running / warmed up completely (you get full heat from the heater or thermostat indicates in the normal range), look at the tailpipe. There should be no visible "smoke." If you see white "smoke" it is probably coolant in the form of steam / water vapor and confirms the crack / head gasket issue. Low coolant / oil levels can also indicate this.
Neither problem is an inexpensive repair - but the a cracked block is usually the "point of no return" that few will fix unless the car is in great shape, low miles, etc.
Coolant and oil leak
have a compression test done as the bubbles suggest a blown head gasket or cracks. That will account for the overheating. The oil leak may be from the head gasket or cracks.
Jan 21, 2014 | 2000 Ford Taurus
Theres a growling noise coming from my power steering
The pump is low on fluid . If fluid level is a-ok check for foam and bubbles in the resvoir. If there is foam and bubbles drain and bleed the resvoir according to spec's. If after all this the pump still growles you may have a bad bearing but before you condem the pump, few more checks you can do. Before I go there lets see how you make out with the foaming and bleeding. Good luck
Mar 05, 2010 | 1998 Ford Explorer
Saturn SW1 will not shift into 2nd, 4th, or reverse
no hydralic fluid in the resvoir look for the resvoir on the fire wall of the drivers side if its empty well fill it back up lol not sure if the sw1 has this but ive had too fix this problem before
Jun 14, 2009 | 1997 Saturn SL
Oil goes into the anti-freeze resvoir
faulty head gasket and dexcool coolant go to the auto parts store get a fel pro gasket n never use extended life coolant its going to cost like 800 to have a shop fix this i would contact gm they are aware of this problem c about having them pay for it
Apr 04, 2009 | 2003 Oldsmobile Alero
A small drip on front side where water comes out of machine
thats your pump. if it leaks all you can do is replace to solve problem.thats the white resvoir looking thing,its a pump
Jan 10, 2009 | Roper RAS8445KQ Top Load Washer
How to check the oil on my toyota torargo 2,2 liter deisel
the oil fill and dip stick is located under driver seat .
There is a door with a black knob that locks and unlocks
Also there is a resvoir for additional quart of oil to seep in
as needed under hood by the battery. Good Luck These
Are GREAT TOYOTAS!!!!!
Dec 19, 2008 | Toyota Previa Cars & Trucks
Plumbing Logo
16 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
