Question about Garden
The vortex door at my industrial shop is hard to pull up and down and I would like to know what I can use to lubricate it. I have tried silicon spray and WD40. Is the some type of lubricant the I can use my email adress is JimtheWCC@roadrunner.com
  • 604 Answers
You may have some wheels that have lost or have frozen bearings. you may also have bent the structure that supports the frame, many times the bearings go out on more than one wheel at a time and will eventually cause the door to be very hard to open/close. you don't say what door you have and Vortex makes many different types and styles. Have you checked the spring loading? It is possible that the lock came loose and you have lost tension, be careful if you are going to try winding the spring yourself, many folks have been hurt trying to increase the tension on the spring. you would probalby be well advised to get a pro to come and look at your door.
Posted on Mar 23, 2011
Drivers side window wont roll up all the way but goes down normally..
Get a can of spray silicone lubricant, and using the nozzle tube, spray down the front and rear guide tracks of the window. Run the window up and down a few times to distribute the lubricant, and the window should work fine.
May 19, 2017 | 2002 Pontiac Grand Am
Trunk door stuck
try spraying silicon lubricant spray in to your key hole. use the straw applicator that comes with the silicon liquid spray. Insert the key and pull the key out of the key hole. Repeat several times then try turning the key lock.
Dec 04, 2012 | 1999 Ford Expedition
2003 Yukon Denali window goes up slowly. Where
You can get away with just lubricating the window runners with silicon or graphite. Don't use oil base lubricant, oil breaks down rubber like the ones use on the window runners. I use silicon and with the spray tube from the can, spray it along the window runners on both side. Towards the front and back of the door, Roll down the window and where the glass runs down in to the door is the runners i am talking about and you should be able to spray along there with the tube and just clean the glass from any over spray. Good luck and this should help.
Jan 13, 2010 | 2003 GMC Yukon Denali
Door locks are hard to pull up and push down. WD-40 on inside of door? KAH
I would recommend a spray silicone lubricant, but WD-40 will also work. Just try to dribble it down the lock mechanism.
Nov 26, 2009 | 1991 Honda Civic
Drivers side window sticks sometimes...does the switch need replacement?
The window tracks may be worn and need to be replaced. You may get away with buying a dry silicon lubricant spray and with the tube nozzle, spray the silicon down on the side of the window tracks. That's where the glass window edge meets the door frame and down in the door. Keep me posted and this should help.
Jun 29, 2009 | 2001 Toyota Corolla
2000 Subaru OutbackWagon
most likely the motor is burning out.
May 15, 2009 | 2000 Subaru Outback
2003 Jeep Liberty rear side window "squeals" when operated down.
I usually spray guide tracks with a silicone spray. It works pretty well. Up north where I am, when sprayed on door seals it keeps doors from freezing closed as well!
Mar 11, 2009 | 2002 Jeep Liberty
The liftmaster garage door opener issues
If you have a Chraftsman/Liftmaster:
1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
  1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
  2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
2. If the door runs fine your gears might br out of your opreator. Open the case and look for a white powder. If you see that and your gaers look worn repace the gaers with 41c4220a gear kit.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
