Question about Hotpoint Dishwashers
I did not put salt in my new dishwasher just used a tablet. DIshwasher started up and then stopped saying water flow problem was this my fault? Rang service desk who were very rude and made a big thing about the salt which I did not think was a big thing since live in softw ater area.
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
Absolutly not your fault robert. nothing to do with salt atal. if its water flow problem could be a faulty flow meter in which case if ur dishwasher is under 28 days u can refuse a repair and demand a replacement.
hotpoint cal centre famous for their rudeness and i hear this complaint regulary about them. they will look for any way to blame you for breaking dishwasher. just be firm with them
Posted on Mar 22, 2011
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
I want to know where to put my dishwasher tablet in my Kenwood KDW4TTSL please. And where does the salt go and how much do I use?
Im presuming that you don't have a manual. If you would like one, you can download a free PDF from here:
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
According to the manual:
There is a recess on the right hand side of the door for detergent (Picture on page 6 of the manual). You can put a tablet in here.
With regard to salt (Also on page 6):
1. Unscrew the cap from the salt container
anticlockwise, which is located on the right side of the
inner box.
2. Load the salt into the container. Each time you may load 250g of salt, which can be used for 15
cycles.
3. Fill the water into the salt container until a small amount of water comes out(it is very important
when you use it for the first time).
4. Screw the cap back carefully.
Note:
1. Load the salt before the beginning of wash cycle so as to prevent corrosion.
2. Load the salt when the salt indicator light in the control panel is illuminated.
3. Only use dishwasher salt.
Jul 19, 2011 | Kenwood KDW4TTSL Dishwasher
Dishwasher is showing low dishwasher salt soon after putting dishwasher salt. why?
Do not bother. Continue using the m/c. If the inlet water quality is good do not worry. This is a sensor sensing fault, even if the salt is fully loaded.
If the wash quality is good without salt continue.
Otherwise add salt at regular intervals. Trying to fix this fault will lead to another and so on. Now machine works for you continue enjoying!
Sep 16, 2010 | Indesit 24 in. D63 Free-standing...
Where do i put the salt in my hotpoint dishwasher ?
If you don't put salt in the appliance then the regeneration crystals will clump together over time and solidify. This will cause a restriction in the softener unit.
If you stopped using it and then started again you may find that the impurities caught by the crystals have simply found their way into the appliance.
You can set the softener to be at minimum setting if you are in a soft water area.
The salt isn't used to soften the water, it's used to clean the crystals in the water softener unit.
Why Do I Need to Use Salt in my Dishwasher?
Salt is needed to ensure that your dishwasher's in-built water softener gives an optimum performance. You will especially need to use dishwasher specific salt if you live in a hard water area. You can purchase one of our Aqua test strips (part number 180876) to determine the hardness of your water from our parts and accessories store or call us on 08448 225 225 .
Manually drain the floor of the machine, put in salt, and check out.
open the salt container at the bottom, and it will be full up with water, and it really will smell bad. clean it and add salt near to 1kg. then run run a prewash cycle and then check out does the salt error is coming up.if yes then more salt needs to be added.
This will help. Thanks please keep updated. please do rate the solution positively.thank you for using fixya
Mar 17, 2010 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwasher not cleaning properly
If I got the issue correct your dishwasher has stopped cleaning properly.
As advised by an Frigidaire engineer that there is not enough salt in the dishwasher & that is what causes the sand like residue on dishes. sometimes even when you use an all in 1 dishwasher tablet this may still not contain enough salt for the hardness of the water in your area. Using salt regular helps keep the dishwasher clean.
I am sure this would help you:
God Bless.
Jul 09, 2009 | Frigidaire Dishwashers
Matsui MF145 beeping continuously
You might want to check the salt and rinse levels on your dishwasher.
Ours was doing the exact same thing and we refilled the dishwasher salt and it worked again. Unscrew the plastic thing on the bottom of the dishwasher and fill it up with about 1 kilo of dishwasher salt, water will flow out when you do this and you can put at least 2 kilos in.
Hope that helps xxx
Apr 02, 2008 | Dishwashers
Miele dishwasher film and crust on the inside-
Hard water has this "crust" which are minerals floating around that ionically attach to everything. Some machines from Miele have a water softener inside the machine. Special dishwasher softener Salt is added that cleans minerals off Xeolite beads. When cleaned they attract mineral ions. If you don't use the salt then the beads fill up on minerals until they can't hold any more minerals. The salt is used in the regeneration cycle. It washes the mineral ions off the xeloite replacing them with salt ions. As new water enters the machine mineral ions slowly knock off the salt ions and attach themselves to the beads again. This whole process keeps the crust off the dishes and the walls of the machine.
Use a dishwasher cleaner that removes scale. And if you don't have a salt light on your Miele you can instead purchase soap tablets that contain water softener built in. Miele dishwasher tablets have it. You can order them online or call Miele.
Dec 17, 2007 | Miele 23 in. Novotronic G841 Built-In...
The salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Mar 30, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Dishwashers Logo
99 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
