Question about Canon PIXMA MP470 All-in-One Printer
Error on screen 5100 color light &
Error on screen 5100 color light & stop/reset light flash
  • Canon Master
  • 1,679 Answers
I just went through this. My problem was that I had something obstructing my print cartridge. I took the back off with 3 screws, then the side panel (on the cartridge side). this was real easy, take the trim off and there is one screw, then find the little arrows that show where the tabs are that slide into the side of the printer itself. I used a flat head screw driver to unsnap them. Once open, I tipped my printer side ways and saw the object in there. Put it back together and now it works.
But the problem you are having could just be as simple as a loose cartridge. Take the cartridges out and put them back in making sure they snap in.
Good Luck!!
Regards,
Ron
Posted on Mar 22, 2011
I want to resolve error 5100 in canon mp 250 series printer pl tell me to do what
Error 5100 show your ink absorver almost full. So reset your printer by using the following methods. * Keep your printer off. * Now press stop/reset button and press power button with holding stop/reset button. * After your power is display a light release stop/reset button but still pressing power button. * Press Stop/reset button two times by holding power button. * Now release both button. * Wait for few minutes until your printer display "0" on your printer LCD. * Now download Canon MP258 reseter ServiceTool_V1050. After
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon MP560 Gets error code 5100
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
Further assistance i am here to help
Please click on Four thumbs which are given below to this solution "if it is helpful"
THANKS & Keep Using Fixya
Mar 13, 2011 | Canon MP560 All-In-One InkJet Printer
I get the 5100 error code. I have done the reset procedure to no avail. The cartridges seem to move normally and there is no obstruction apparent. Any suggestions on how to fix? Thanks, Terry
Hi
Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip (encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply. Hope this helps...please post back for further assistance.
Daniel
Jan 08, 2011 | Canon Pixma MP450 All-In-One InkJet...
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Canon Pixma MP450 All-In-One InkJet...
ERROR 5100 CANON PIXMA MP 450 It does not work when off from KOPJUTER
Hello
Dec 17, 2010 | Canon Pixma MP450 All-In-One InkJet...
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error 5100
Hello! Try this:
1. Unplug the power cord
2. While pressing the ON button, plug the power cord back in.
The power light should flash an orange/yellow color.
Continue pressing the ON button, and press the RESUME button 4 times. The light changes every time you press it.
3. Release both buttons, and restart the printer.
The printer should now stop blinking and operate as usual.
I hope this works for you. OMS
Apr 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP470 All-in-One Printer Logo
24 people viewed this question
old marine
old marine
